PLEASE HELP OUT WITH TIRE SIZES
Old Apr 20, 2003
gerzdavj's Avatar
gerzdavj is an unknown quantity at this point
I JUST WANT TO KNOW IF 215/45/17 ARE TO BIG FOR OUR CIVIC OR TO WIDE WITH A 1.75 LOWERING FROM GOLDLINES. I AM BUYING SOME MOTEGI RT5'S AND IM THINKING ABOUT GETTING 16S OR 17S. I DONT LIKE THE 40 SERIES TIRES ON THE 17S THERES NO MEAT ON THE TIRES AT ALL.IF I CAN PUT ON 45 SERIES TIRES ON MY 17S I WILL GET THEM IF NOT I'M GOING TO GET 50 SERIES WITH 16'S
Old Apr 20, 2003
TheRock's Avatar
TheRock is an unknown quantity at this point
I have 215/45/17 on my vic, and I think they are perfect. I also have the goldlines. imo go with the 17s
Old Apr 20, 2003
S2000man01's Avatar
O RLY
A, caps lock please.
B, wrong forum.
Old Apr 20, 2003
CivicEnvy2001's Avatar
CivicEnvy2001 is an unknown quantity at this point
With the 45's they might rub, but if you're worried about your car being too low, you could go with coilovers so you can adjust it to the lowest possible height w/o it rubbing since you don't like the 40 series tire.
Old Apr 20, 2003
Distinctive's Avatar
Smell My Face!!
Talking
yeah thats what i would have told ya
Old Apr 20, 2003
civicvtec1ps's Avatar
Search and Learn
you wont rub with 1.75 drop.
Old Apr 21, 2003
Frank2sy's Avatar
Frank2sy is an unknown quantity at this point
I think they are talking about the rear tires. The rear tires stick out too much, so they will rub against the rear fenders when going over bumps. I have the same setup.
I don't know if going over to coilover will avoid this problem. Civic's rear tire well is just too small for 215 series tires.
Old Apr 21, 2003
Frank2sy's Avatar
With what I said above, I'm assuming you will install rear camber kits, and align to Honda's specification after lowering your car.
Old Apr 21, 2003
I have 215/40/17 tires and they aren't too wide. They are actually the perfect width.
Old Apr 24, 2003
NorrinRadd's Avatar
NorrinRadd is an unknown quantity at this point
Frank2sy is correct with a 215/45/R17 setup your rear tires will somtimes rub if you have a 1.75" drop and negative camber. I had the exact same tire setup and Goldlines 1.75" drop and my rear tires rubbed going over bumps (but only if there were people in the back seat). Mind you my rear camber was negative, so when I got a camber kit installed and the camber was good I went from sometimes rubbing to most definitely always rubbing going over bumps w/ just me in the car. Just like Frank2sy stated our car's rear fender cannot handle such a setup, but what I did to resolve this for a measly $70 was to take it to a body shop and have them plasma cut out portions of the rear fender to allow the tires totuck under w/ good clearance. I highly suggest anyone w/ 215+ width tires to do this, if you have 205's or less you should be Ok. Hope this info. helps you and everyone else with this issue...
Theshwartz35
Jul 17, 2015 11:13 PM
Genyc07
Wheels and Tires
Jul 11, 2015 05:51 PM
muttleytm
Jul 8, 2015 04:13 PM
BootyDo
Jul 7, 2015 06:06 AM
Causemo
Jul 5, 2015 06:42 AM
