RSX Type-S brakes and suspension swap??
Old Mar 7, 2003
cosmo's Avatar
cosmo is an unknown quantity at this point
I was wondering what would be involed with swapping the brakes and the sway bars from a new RSX Type-S to a 2001 Civic LX. Would the brake swap (4-wheel discs) be hard or would it be close to a bolt on, and what about the sway bars? Does anyone have a DIY or know how much work is involved with this? Any help is appriciated.
Old Mar 7, 2003
Friedrice's Avatar
Friedrice is an unknown quantity at this point
All I know for sure is that the rear sway bar fits perfect if your car already has it, so that depends on what year your LX is. The other stuff I'm not sure about, but I'm interested to know about the brakes, and what about struts and springs?
Old Mar 7, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
Check with mugenracerX (aka. Greg, Hondawerx guy)... He knows the ins and outs of the DC5 suspension swap because he and DC5@EM2 have the ITR suspension and brakes in the swap car. I don't know what was modified to fit them in, but I doubt too much. I take it you realize you're gonna need new rims... RSX has 5 lugs.
Old Mar 7, 2003
Jodster's Avatar
Post Whore General
from what I've been told you can swap the rear disc brakes from the 02 and up SI HB.
Old Mar 9, 2003
cdmx's Avatar
Quote
[hr]Originally posted by: Jodster
from what I've been told you can swap the rear disc brakes from the 02 and up SI HB.[hr]
good to know
Old Mar 24, 2003
yositoco's Avatar
yositoco is an unknown quantity at this point
I bought all the brakes from the rsx type s, including the control arms. Im going to the swap in a couple of months since I dont have time to do it during the semester.
Also installing the rsx wheels. Ill let you guys know.
Old Mar 24, 2003
HondaLuver's Avatar
Its a celebration bitches!
pretty much we have the same suspention set up... the wheels might stick out a little too much because the original width of the rsx's are wider...
you can pretty much get any suspention mod for the rsx and put it on our cars will little or no modification.
as far as i know, the front and rear strut bar fit( except for the intake in front) the sway bars fit, and the tein flex dampers fit with little modification, pm aswzero about this.
Old Mar 24, 2003
BlAcKBeAuTy's Avatar
BlAcKBeAuTy is an unknown quantity at this point
i dont htink you can put the rsx stock wheel on our vics, cause its 5-lug pattern right?? you'd have to swap out the axels too wouldnt you?
Old Mar 25, 2003
Travii's Avatar
Travii is an unknown quantity at this point
I know that for the rear sway bar you are going to have to "make" brackets. Your car doesn't come with one so you don't have the factory brackets like the rest of the years.
Old Mar 29, 2003
DarrenA's Avatar
DarrenA is an unknown quantity at this point
Did anyone ever find out if we could swap everything including axles?
Old Mar 30, 2003
AntDeezy's Avatar
I am thinking Civic Si would be very much easier. has anyone done it yet ? I am going to look into it for sure .....
7thgensurvivor
38
Aug 29, 2015 11:50 AM
bsmiley
Apr 27, 2015 01:27 PM
Mokushi
Jan 9, 2002 09:16 AM
TaiChi
Dec 17, 2001 09:09 PM
Vtecpwr
Nov 11, 2001 10:17 PM
