The perfect setup for a sedan with 18s??
Old Mar 29, 2003
98VTEC's Avatar
98VTEC is an unknown quantity at this point
Hey guys I need some help...I'm a new member here and yes I have searched a bit so don't flame right away. My girlfriend owns a 2k1 civic 4 door, and I'm trying to help her out with a problem she is having with her 18's. She got the wheels a week ago in the same offset as my Prelude +48, which for me works fine...but for her causes massive rubbing. She isnt even lowered at all. After a bit of searching I found that +42 is a much better offset for Civics. Anyhow, what should I do? Sell these wheels and get new ones? My question to you is this....what offset do I need to safely lower her car 1.75 inches, what kind of camber problems will she have? Below is here current setup...and then what I want to get. Any feed back would be great!
Currently:
Stock suspension w/ Volk LE-37Ts 18x7.5 w/ 215/40/18 Pirelli P7000 tires +48 Offset
I figure sell the rims and get....
Koni Yellows and Ground Controls
Racing Hart C5 Evos 215/40/18 tires with a +42 offset
Will I need a camber kit?
Thanks guys!!!
Old Mar 29, 2003
Falcon's Avatar
Falcon is an unknown quantity at this point
i also get rubbing with 18's with a 42 offset
its becuse the tires are 225s
get smaller tires, 205s seem to be working well for people
Old Mar 29, 2003
R1Style's Avatar
18's will generally rub in the rear of all 7th gen civics. What you need are wheel spacers, not to buy new rims.
Old Mar 29, 2003
666's Avatar
666
666 is an unknown quantity at this point
I agree, find a set of wheel spacers (H&R makes them) and put those on. The LE-37's are too nice to sell!! A different tire size no wider than 215 should help too, with a 35 or 40 sidewall.
Old Mar 30, 2003
Beaver's Avatar
Beaver is an unknown quantity at this point
And yes you will need a camber kit if you lower it 1.75 inches
Old Mar 31, 2003
Jackseric's Avatar
Jackseric is an unknown quantity at this point
So the rubbing actually occurs in the rear?? *****! all this time I thought I was going to have to worry about the front wheels rubbing when I turn. Hmm... wondering if 18s are the way to go...
cukaracha
Aug 27, 2015 02:02 AM
Strycker
Aug 2, 2015 08:40 PM
bdrickybd
Jul 29, 2015 07:15 PM
