New Rotors???
New Rotors???
Im pretty sure mine are messed up, i let some new kid at work change my pads and he turned my rotors and they have grooves in them now
are these brembo rotors good quality and a good price BREMBO
and if i buy these rotors are they ready to use or do i have to do anything to them before i put them on,
any help will be greately appreciated
The Standard One
wrong section..
i heard you can get brembo blanks(what those are) for $17 each at nopi. and you can get brembo drilled/slotted rotors for 150 a pair from someone in socal.
Quote
[hr]Originally posted by: Crash2002
i dont see it at NOPI can someoen help me out?[hr]
http://www.nopionline.com/index.cfm?...mance&vaffid=0
And to put them on, make sure you have some break component cleaner...
Remove the wheel, remove 2 bolts on the caliper, remove the caliper, remove 2 small screws on the rotor, remove the rotor, apply new rotor and screws, spray down with break cleaner, put in new pads, put back caliper, put back wheel. It's more simple than you think...there's a DIY for it here. Hope that helps!
And remember, it's a very very good idea to put in new pads with new rotors so the two seat together more properly. And breaking in is key for maximum breaking performance.
Tirerack has brembo blanks for fairly cheap as well here...just make sure you put the proper make for your car (this is for an ex coupe). From previous gens, the best combination I've heard of is Brembo blanks and AEM pads. Give me a PM if I can help more!
T-X
I need TP for my bunghole
Hello;
You can get the crossdrilled from Tirerack.com for $161.00. Those will keep the rotors coller and help keep them from warping and glazeing from brake heat.
7th gen civic rotorstirerack.com - search for your year and make.
Cross-drilled/slotted doesn't help unless you're under extremely heavy breaking conditions! It's a myth unless you're autocrossing! You get it for the looks...nothing beats a pair of blanks - no chance of warping because it's one solid piece!
Autocross Junky
Avoid Drilled rotors!!! they are prone to braking. Slotted is the way to go. especially if you autocross like me.
even Brembo says that their drilled rotors are not recomended for race use or for use on the street in conjunction with High performance brake pads. they even say Drilled rotors give a "Ready to Race look"[IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG]
Junquito89
Sep 27, 2015 10:22 PM
Bruce2
Sep 27, 2015 08:45 PM
pilebuck13
Sep 21, 2015 10:45 PM
