DIY: Brake Pads and Rotor Install *Updated*
Old Sep 25, 2007
  #91
edicivic2k1's Avatar
edicivic2k1 is an unknown quantity at this point
Re: DIY: Brake Pads and Rotor Install *Updated*
Originally Posted by Sara-Lee
Grey, thanks for the best guide I've seen on the net.
Grey, ditto. I just reread some of your DIY's for reference, I am preparing to do my timing belt! You definitely have a good eye for detail.
On my Civic, the rear pistons are threaded. You have to screw them in, not push them in using a c-clamp.
You also have to unclip the handbrake cable before you can remove the caliper. The length and position of the brake fluid pipe also makes it impossible to use the trick of unfastening the bottom nut and flipping the caliper up. Instead you have to wiggle and push to lift the caliper off.
I found that my Civic had non-standard pads: that is, they didn't match the model and year chart at Halfords, or online. I guess this isn't usual. But before buying pads, I wished I had taken them out and drawn the profile and measured. That would have saved a lot of time.
Uh, Feminazi Sara-Lee, may I suggest, and this is just a suggestion, that you leave the year, and model of your vehicle so that you can add intelligence to this thread? There may be others in the same [let's hope not, but, I guess it is possible] predicament as you.
Then a couple of other notes. First for the admin: I thought this stuff was worth leaving as a note, but I really had to struggle to register. The registration form seemed to be adding in blanks and line breaks in the email sent out. It might just be me, but...
Uh, Feminazi Sara-Lee, if you are struggling to register to this website, you may want to board the short bus tomorrow morning.
And lastly, to add a bit of petrol to a fire... Manutd0018 and and dru016, what kind of ***** are you to use pictures like that? Are you maybe 13 years old, not 18 and 16 like your names suggest? Girls drive and mod Civics too.
Uhhhh, Fem-i-****, Sara-Lee, for the most part, folks on this website are from the U S and A. Here, we have privileges that allow us to make choices on our own. Just like your unfortunate choice to leave a comment here on this forum!!
No need to reply. This is a one time posting. And, no I'm not a lesbian, and yes, I do get quite a lot.
Feminazi Sara-Lee, are you sure about this? Have you discussed this with anyone?
Thanks again Grey for the brilliant howto,
Sara-Lee
Feminazi, this is the only comment you made that raised our trust in your intelligence. Sorry Hunny, [if you are a chick.]
Bye.
Oh, and Feminazi? No need to reply. This is a one time posting.
Old Nov 18, 2007
  #92
eruffini's Avatar
eruffini is an unknown quantity at this point
What would be a disadvantage to NOT greasing the back of the brake pads?
Old Nov 18, 2007
  #93
tfnaaf's Avatar
BLDNPSI Mod
its not a dis-advantage to not put it on the back but an an advantage to put it on the back as it MAY reduce brake noise
Old Nov 18, 2007
  #94
eruffini's Avatar
Thanks!
Old Jul 22, 2008
  #95
Dash555's Avatar
Dash555 is an unknown quantity at this point
Has anyone else noticed a slight vibration coming from the brake pedal during moderate braking after installing cross-drilled rotors??
Old Jul 22, 2008
  #96
tfnaaf's Avatar
BLDNPSI Mod
If you have a vibration after new rotors its not from them being slotted. Its from not indexing the rotor to the hub to minimize run-out. Max run-out is .003" (.004" per honda ) and the best way to cure the problem now is to have them machined on the car!
Old Aug 31, 2008
  #97
DarkFlame's Avatar
DarkFlame is an unknown quantity at this point
Grey, great DIY. I've done brake rotor/pad replacements on most of my vehicles, & your DIY seems spot-on. But I do have a couple of questions:
1-) I never know the difference between "right-hand" & "left-hand" threads. "Standard" threads are clockwise to tighten & counter-clockwise to loosen (as my wife says: "Righty-tighty & Lefty-loosey"). But which way to tighten/loosen "right" or "left" hand threads?
2-)We have always bled brake lines by attaching a piece of rubber hose to each bleeder nipple an pushing the other ends into clean soda bottles half-full of fresh brake fluid, then bleeding the brakes individually, starting with the one furthest from the master cylinder (longest line) & ending with the one closest to the master cyl (shortest line). this allows a single person to bleed the lines - w/o help. of course, one must always be careful to not let the master cyl run dry. however, it has always worked for me, and I've never needed any help bleeding the lines. Is there a problem with this method?
3-) & here's why I'm wanting to UPGRADE the brakes & not just "replace" the pads & rotors on my Civic ('98 LX w/90k "all mine" miles): the rotors always seem to warp before the pads get halfway worn out! (and, I want to drive the thing another 10 years or so w/o having to replace the rotors several more times. SO, what would be the best heavy-duty rotors available?
Please excuse any typos - I'm typing this on my PocketPC from the hotel room (kids & wife are asleep) while we're out of town, and my fingers are fatter than these keys!!!
Thanks for sharing your expertise,
David
San Antonio, TX
Old Dec 8, 2008
  #98
00telehit's Avatar
00telehit is an unknown quantity at this point
I have ROTORA BIG brAKE KIT ON MY CIVIC, THEY ARE AWSOME WAY BETTER THAN BREMBO, BUT IF U WANT BETTER THAN ROTORA, U CAN GO WITH WILLWOOD BRAKE SYSTEM, OR ENDLESS .........THEY ARE GREAT, BUT U GONNA NEED A TON OF CASH.
NOTE: this pics are from my old civic, this same rotora brake system it ll be install in my new EM2, i have a bunch of after market parts sitting in my garage, but im waiting for the winter to be over, so by spring i ll put the big brake kit, and the other stuff, i need this EM2, really clean jdm style, for the beginning tour of HIN in april.
and to explain thing better, as u see in this 2000 civic ferio, it has a set of advan wheels, those wheel are now on my EM2, here is a pic.
Last edited by 00telehit; Dec 8, 2008 at 09:35 AM. Reason: because i need to add something else , that i forgot
Old Dec 8, 2008
  #99
sl33pyriceboi's Avatar
^ur car looks ridiculous... drop that poor thing
Old Dec 8, 2008
  #100
supafil25's Avatar
supafil25 will become famous soon enough
going back to the first post
if you dont know how to do brakes you shouldnt work on a car.
Old Sep 7, 2009
  #101
02Hondadx's Avatar
02Hondadx is an unknown quantity at this point
Originally Posted by streetglower
So basically before I bleed the brakes I take out as much fluid from the resovoir and then put new fluid in there. Then I start with one brake and bleed it and then add more fluid when it gets low. Then I do this 3 more times, then fill it again at the end. So I need to fill it after bleeding each brake.
Just don's drain all the fluid out, other wise you will have a bunch of air in the lines and that is not good.
Old Sep 7, 2009
  #102
02Hondadx's Avatar
True, but you have to know how to do it eventually. I know how but, there are some people that are new to the whole working on your own car thing.
Old Dec 6, 2009
  #103
02Hondadx's Avatar
No i havent had any problems. I had a slight grinding at first but after a few hard braking stages to heat up the pads it went away. Sometimes with ceramic pads/rotors there could be a bur in the metal. but it will soon go away, like i said with a few hard braking tests. Recommend doing this in a neighborhood, or not as busy road
Old Aug 28, 2010
  #104
azcat90's Avatar
azcat90 is an unknown quantity at this point
Are we supposed to put grease on the cailper pins - pull them out from the hole covered by the rubber boot and dip them in grease?
Old Aug 28, 2010
  #105
MindBomber's Avatar
Live for the Twisties
Yes, is a good idea to grease those.
Just slide it most of the way out and put grease on it.
Old Sep 23, 2010
  #106
JRunyon21's Avatar
JRunyon21 is an unknown quantity at this point
I tried changing my brake pads and rotors yesterday and ran into a small problem. Everything went well until I got to the last brake pad(The pad on the outside of the caliper). The pad slipped in and when I went to put the caliper back on it would not fit over the rotor. Before jumping to conclusion, I already used a C clamp to push the piston all the way back. When I try to put it on it is getting caught between the outside brake pad and the inside of the caliper. I repeat, it is not getting caught between the two brake pads. It is getting caught between the outside brake pad and the caliper itself.
I fooled with it for over an hour.
I put the old pad back in so I could make it to work today.
Any suggestions?
Old Nov 7, 2010
  #107
Kyle23's Avatar
Kyle23 should not be trustedKyle23 should not be trusted
Any suggestions?
Are they Weaver Silver pads from Advance Auto Parts? I read a few reviews that said the pads were too large and wouldn't fit...
Old Feb 25, 2011
  #108
05civicdallas's Avatar
05civicdallas is an unknown quantity at this point
i know im pullin a old thread. so i dont get burned for starting a new one.
I just wanted to ask if anyone gots a trick to get off them damn screws that hold the rotor on. i have been spraying them down with WD-40 but no help i could only get off one.
i have already broke the handle off one of my screwdriver
Old Feb 26, 2011
  #109
billkisme's Avatar
billkisme is a jewel in the roughbillkisme is a jewel in the roughbillkisme is a jewel in the roughbillkisme is a jewel in the rough
most likely you will have to drill them out and get new ones or use a impact screw driver. Im not sure if thats the real name of it or not. but if you just drill them out and just pull the rotor off you can then just grab whats left of the screw and pull it out
Old Mar 14, 2012
  #110
gklayton's Avatar
gklayton is an unknown quantity at this point
One step you forgot to mention: Pushing brake piston back
Because your older brake pads would've been worn out and the new ones aren't you will need to push the brake piston back into the caliper. To do this:
1. Open brake fluid reservoir lid
2. Using adjustable pliers, smoothly squeeze the piston back into the caliper
You should now be able to put the new brake pads.
Old Apr 16, 2012
  #111
Rahway09's Avatar
Rahway09 is an unknown quantity at this point
How much would new brake pads and rotors cost?
Star1967
Jun 8, 2015 04:23 AM
masongap
May 26, 2015 07:55 PM
rhvic
May 22, 2015 03:06 PM
ayoitzjulesdx98
May 14, 2015 08:29 AM
bsmiley
Apr 27, 2015 01:27 PM
