New tires, new tire pressure?
Rep Power: 0 New tires, new tire pressure?
I guess I'm an idiot when it comes to tire pressure, but I got new tires yesterday and they are a different size than my stock tires. Will I have to keep them at a different pressure? My stock tires were 185/70/14, the new ones are 195/60/14. Thanks.
Rep Power: 0 Stay with 30....that is what the placard suggests in the door jamb...that pressure is set up for the car and its weight, not the wheels themselves whether you are running 15's or 18's...I agree about rechecking when the temp goes down...I just checked mine and it has been like around 20 degrees here during the day for the past couple of weeks...
2Hottie
2Hottie
Rep Power: 0 remember this good rule of thumb:
10 degrees (F) = 1psi
so, if the temp drops 20 degrees in a few months, i.e. summer to fall/winter, youll have to add 2psi all around, then when it gets warmer in the spring youll need to let out some air. then when it gets hot, you may have to deflate them more. this is why its important to check/adjust your pressure before you start driving.
OptimisticWay
46
10-15-2015 02:16 PM
hondadriver95
07-13-2015 09:43 PM
BootyDo
07-07-2015 06:06 AM
Causemo
07-05-2015 06:42 AM
