Slotted Rotors?
Extreme Member
Slotted Rotors?
Hey everyone, I have way too much excessive squeaking coming from my front disc brakes and no matter how much I clean the pads and rotors, they keep doing it again soon after. I know stock civic brakes blow so if I go ahead and invest the $80 in the new slotted discs in the parts section, would that reduce, if not, stop the squeaking?
have you tried the variouse stop squeak type products that you find in auto part stores? They sell some orange colored goo that gets spread on the back side of your pads to keep the vibrations down. I doubt that slotted rotors will solve you problem. But they look cool and function better than oem under harsh conitions.
that used to happen to me too... get the anti-squeal spray/gel and spread it on the back of the pads (sandwiched between the pad and anti-squeal shim) and reinstall. Also, spray the rotor and caliper down with brake cleaner. That should do it!
danace99
Oct 17, 2015 02:51 PM
Junquito89
Sep 27, 2015 10:22 PM
Bruce2
Sep 27, 2015 08:45 PM
pilebuck13
Sep 21, 2015 10:45 PM
