Low profile tire problem-HELP
Old Nov 20, 2002
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
Well i recently went to have a rear tire patched at NTB. When i was there i figured i might as well let them rotate my tires. Well when they removed my rear tires they noticed that the top inside of my tires the tire tread was kinda bumpy like sort of small rolls nothing like indentions but kinda like small hills on my tread. I have a camber kit but have not had it adjusted since i had it installed early this past summer. I was wondering if you all had any info. on how to prevent anymore wear or what your 2 cents might be?? thanks
INJEN
Old Nov 20, 2002
rickinthescv's Avatar
rickinthescv will become famous soon enoughrickinthescv will become famous soon enough
I would have the vehicle realigned. It sounds to me as if your toe in is off, meaning your wheels are slightly not parallel.
You need a good four wheel alignment. If your camber was off, you would have an even wear pattern on the inside edge of your rear tires.
Old Nov 20, 2002
nytejade's Avatar
nytejade is an unknown quantity at this point
Quote
[hr]Originally posted by: injencivic
INJEN[hr]
You answered your own questions. Just get an alignment man. Any time you modify the suspension you should get an alignment.
Old Nov 20, 2002
injencivic's Avatar
the car doesnt need an alignment but the toe is a great possibility. i will keep that in mind
INJEN
Old Nov 20, 2002
aetobatus's Avatar
n00b
aetobatus is an unknown quantity at this point
If your wheels are well balanced, then you will probably need alignment.
Driving on unbalanced wheels for a while can cause the same problem too.
Old Nov 20, 2002
VNlilMAN's Avatar
The Standard One
Quote
[hr]
uh.. toe is part of the alignment
Old Nov 22, 2002
kevrod's Avatar
kevrod is an unknown quantity at this point
toe is defintely part of the alignment
cukaracha
Jun 7, 2015 03:32 PM
bsmiley
Apr 27, 2015 01:27 PM
bo_red
Apr 23, 2015 10:09 PM
Inspired2k1
Nov 14, 2001 05:18 PM
technosilver
Nov 14, 2001 10:58 AM
