will older civic rims fit 01's
Old Oct 16, 2002
BlueStepSide's Avatar
BlueStepSide is an unknown quantity at this point
i am looking at getting some rims for my g/f's 01 cp civic and i was wondering if rims off of a 99 or 00 would fit her car....i woulf figure that they would cause i THINK they have the same lug pattern but it would be a great help if yall would help me out...thanks
any suggestions on rims for a stock 01 civic red with tinted windows....thinking 17's
Old Oct 16, 2002
Boilermaker1's Avatar
Jap-Euro Fusion
These are off the 00 Si.... I think Civics from as far back as 92, maybe even 88 all have the same 4x100 bolt pattern.
Old Oct 16, 2002
vincenzobar's Avatar
THE WOP
vincenzobar is an unknown quantity at this point
as long as the rims are 4 lug 100... they will fit.
Old Oct 16, 2002
THE WOP
Also the bigger the rim the less speed of the line and handling demishes. I like 16 with a lil rubber (45 - 50 aspect ratio) they make tires like yokohama that are reinforced with steel sidewalls so your handling isn't compromised with height and your ride will be smoother. Also with this diameter of tire you won't have to worry about rubbing ever. I only rub becuase mine are 225 wide. My next set are going to be 215 or less.
Best of luck.
Old Oct 16, 2002
StreetTrendz's Avatar
StreetTrendz is an unknown quantity at this point
Get bronze velox or somethinf like that...
Old Oct 21, 2002
nochopstix's Avatar
nochopstix is an unknown quantity at this point
yes they will fit. the lug patterns are the same
CarStuff
Dec 6, 2020 12:52 PM
Jon-Ohio
Jun 30, 2018 08:10 PM
aus10
Apr 13, 2015 09:26 PM
