brake rotor rust removel
Old Sep 4, 2002
drang01's Avatar
drang01 is an unknown quantity at this point
This may or may not be a lame question but is there anyway to remove the rust off a rotor without messing things up.. or is that just something I'll have to replace if I want it to look good???
Old Sep 5, 2002
2Hottie's Avatar
2Hottie is an unknown quantity at this point
Hey bud...
Can remove rust temporarily with a wire brush or steel wool...but once you run it in the rain again a few times, it will be right back to the way it was...the stock brakes suck, just gather a lil money and get some cross-drilled or slotted rotors...worth the money and they won't rust!
2Hottie
Old Sep 5, 2002
civicdee's Avatar
civicdee is an unknown quantity at this point
I don't know about the no rust aftermarket rotors.
I had a set of Brenbo cross drilled slotted rotors on my last Civic Si and they rusted worse than the stock rotors. I hated them. I know there are some highend rotors out there that are coated that might not rust though.
Old Sep 5, 2002
1955's Avatar
i thought brembo is a hign end product
Old Sep 6, 2002
ACEM2's Avatar
NytRyder2k2's Son
ACEM2 is an unknown quantity at this point
Brembos are high-end brake rotors, but if you dont zinc coat them they will still rust. I didnt zinc coat mine and they look like a$$. So I just went ahead and got AEM Rotors instead cuz I couldnt bear looking at the rust. SO be sure to zinc coat ur rotors.
Old Sep 6, 2002
2Hottie's Avatar
Yeah, for sure, the Zinc coated ones won't rust...my buddy has cross-drilled Power Slot rotors on his Altima, and thru tons of washings and rain storms, no rust!!!
2Hottie
Old Sep 6, 2002
1955's Avatar
[IMG]i/expressions/beer_yum.gif[/IMG]oh that settled the rust issue then,i saw a article on 4 after market brake kits in the august/september "sport compact car"magazine,the brembo is about close to $3 grands,i may need to swap performance brake pad first cus i dont have the green.
sorry that was the Car and Driver september issue..www.brembo.com,www.stoptech.com,www.tirerac k.com
tirerack sells both Prodrive brake kit and just Hawk HP Plus pads
Old Sep 6, 2002
2Hottie's Avatar
Yeah, that is what I am doing, getting the greens and maybe the Power Stop or Neuspeed cross-drilled rotors...
2Hottie [IMG]i/expressions/beer_yum.gif[/IMG]
Old Sep 15, 2002
dacivic's Avatar
dacivic is an unknown quantity at this point
So where can you get this zinc coat?
Old Sep 15, 2002
InanimateCarbonRod's Avatar
InanimateCarbonRod will become famous soon enoughInanimateCarbonRod will become famous soon enough
I just painted my drums/rotors/calipers with high temp epoxy engine paint. Looks MUCH better now.
I used low gloss black paint, I'm not after the flashy caliper/drum look. To tell the truth, I want to draw the least attention to my tiny brake rotors and rear drums.
pizzahutcombo
Suspension
Jul 13, 2021 09:41 PM
Strycker
Aug 2, 2015 08:40 PM
DerbyDad03
Jul 27, 2015 11:34 AM
Brandon Vlasak
Jul 25, 2015 07:25 PM
General 7th Gen
Jul 9, 2015 10:17 PM
