Difference in 2nd bolt pattern..does it matter?
Old Jul 2, 2002
Seveneighty's Avatar
Seveneighty is an unknown quantity at this point
Wheel 1: 16" x 7" (Bolt Pattern 1: 4/100) (Bolt Pattern 2: 4/108) (Offset: 42 mm)
Wheel 2: 16" x 7" (Bolt Pattern 1: 4/100) (Bolt Pattern 2: 4/114.3) (Offset: 42 mm)
I'm not sure which wheel is best for my Civic. As you can see, they're exactly the same, except for the "bolt pattern 2", which is 4/108 compared to 4/114.3. Does this even matter? Or is one better than the other, for my car?
Old Jul 2, 2002
CivicMexicano's Avatar
El Pinche Turbo Mexicano
CivicMexicano is an unknown quantity at this point
They are the same doesn't matter witch one you choose they both fit right..........
Old Jul 2, 2002
NickDaMans02Civic's Avatar
NickDaMans02Civic is an unknown quantity at this point
Wow I was going to ask this question too so no matter what the other bolt pattern on the wheel as long as it 4/100 then it will work excellent now just have to find out what these Tuner Stlye Lugs and Locking Lugs do on the RS6. Any ideas on which one I need or both of them?
Nick
Old Jul 2, 2002
2cute's Avatar
2cute is an unknown quantity at this point
The bolt pattern 2 is most likely the list they have for other rims and lug patterns. The 4/100 is the one you need. When places list their rims they tend to list them that way which shows the different patterns they have for the rim. Your car has a 4/100 lug pattern. Sorry if that doesn't makes sense. Basically don't worry. Tuner style lugs are a ploy to get people to buy them. Locking lugs are the lugs that you need a key to take off. The thing that sucks about them is if you get a flat and don't have the key with you are kinda scr*wed. When you get rims you will need to get new lugs. Best idea is to ge the lugs where you get your rims and have them give you lugs that will fit the rim. Different rims require different lug nuts. As far as buying them, here in San Diego, when you go to like Discount Tire they automatically give you locking lugs.
Old Jul 2, 2002
StreetTrendz's Avatar
StreetTrendz is an unknown quantity at this point
Quote
[hr]Originally posted by: NickDaMans02Civic
Nick[hr]
Nick the tunner style lugs are the ones that are open (don't have a top) and they have a key that goes inside them so you can use a regular socket and lcks have a special key that noone else has for security measures...
Old Jul 23, 2002
rickinthescv's Avatar
rickinthescv will become famous soon enoughrickinthescv will become famous soon enough
Go with the McGard Tuner lugs. They are awesome and are locking already. Plus they are closed end and come in colors. They are a bit expensive, but hey they only hold your wheels onto your car at high speeds right?
manfredww1
Jul 14, 2015 10:24 AM
f575gtc
Transmission
Jul 13, 2015 09:16 PM
Kyles24
Jul 12, 2015 09:15 PM
06Si_Girl
Jul 12, 2015 12:08 PM
ballmich
Jul 9, 2015 11:59 AM
