Converting rear brakes.
Re: Converting rear brakes.
Very much so. Quite easy to do, no less. Was the second l, maybe 3rd mod I did on my 2002 civic. Used the diy guide below, barely knew how to do anything more than change oil, brake pads, and change a tire when I did them
02-03 EP3 rear knuckle assemblies bolt right up. Just make sure they're 4x100 boot pattern. You'll need RSX or Acura 1.7el e-brake cables, too. If you wanna get the most out of them (though, not 100% necessary), swap out your brake proportioning valve with the EP3 one.
https://www.civicforums.com/forums/4...elled-out.html
kasimmmmm
Sep 6, 2006 12:38 AM
EM2typeflex
Dec 21, 2005 09:38 AM
