banjo bolts
Old 10-10-2016
ThatD_17's Avatar
ThatD_17 is an unknown quantity at this point
banjo bolts
Are banjo bolts universal, because I am having the hardest time finding ones that directly fit a 2001 honda civic! Please help if you know this!
Old 10-10-2016
Prelude Owner
GolNat's Avatar
Re: banjo bolts
They have different threads.
Did you check with dealer or Majestic Honda online catalog to get thread type?
Old 10-10-2016
Re: banjo bolts
Banjo is a design, not a size.
Order what you need from a dealer or grab a correct used one from a recycle yard. Get the seals too.
Old 10-11-2016
ThatD_17's Avatar
Re: banjo bolts
yea I know what it means by banjo. Im not trying to spend my arm and leg at the dealership. And the reason I am getting new ones is mostly because the old ones are, well, old and corroded so I'm not trying to get another set like that from the junkyard.
Old 10-11-2016
Re: banjo bolts
Corrosion....You must be looking for caliper/brake line banjo bolts instead of trans cooler line banjo bolts....I've seen them included with reman calipers, check your parts stores?
Old 10-11-2016
ThatD_17's Avatar
Re: banjo bolts
yes for the disk brakes, and yea Oreillys has them on their shelves but I do not know if they are the right ones ya know? And the people there are no help never are at my oreillys.
Old 10-11-2016
Re: banjo bolts
Take yours in as the example, or ask for a reman caliper for your car and one banjo bolt, and see if it screws in cleanly. Keep correct bolt and don't buy the caliper.
ezone
05-06-2021 07:41 AM
janerz12
04-01-2016 08:56 PM
Nalmonte
03-22-2016 11:31 PM
WEG
03-22-2016 11:29 PM
Theodorekaminsk
03-15-2016 12:35 AM
Quick Reply: banjo bolts
