axle cv joint
Old Mar 23, 2016
Kristoliquid's Avatar
Kristoliquid is an unknown quantity at this point
axle cv joint
So im gonna change my 4 suspension and at the same time when i do a sharp right turn i hear a loud KLUNK! KLONK! probably the axle thats finished.
When pulling it out there is some transmission fluid coming out.
Lets say im gonna do both, since my mcphersons will be pulled out.
Is the loss of transmission fluid significant?
How much should i lose when pulling the axles out?
And should i look at my transmission fluid gauge after running the car a little bit or when its cold?
Anb i just add whats missing?
thx.
Old Mar 23, 2016
Poopies's Avatar
Super Moderator
Re: axle cv joint
I don't know, is it?
I'm not sure, but you might as well do a drain and fill afterward. It's hella easy.
Not sure, my 5 speed uses the Finger Gauge You usually drain and fill when it's at least warm, so probably that.
An[d] i just add whats missing?
See above.
Old Mar 24, 2016
Re: axle cv joint
Can i install any kind of axle or i need to install one for auto transmission or manual exactly.
Old Mar 24, 2016
Re: axle cv joint
ok let me rephrase that because i only had 30 seconds to type that before going back to work
civic si (canada)
I need to change both front wheel drive axles, My car is automatic transmission. Can i install a front axle thats labeled manual transmission on my car?
aztecaa
Nov 29, 2015 04:21 PM
steve6
Nov 22, 2015 08:18 PM
Crimson
Nov 3, 2015 06:53 PM
Othelius
Oct 23, 2015 07:25 PM
CraigW
Oct 13, 2015 08:56 AM
