2 Problems
Old Aug 8, 2014
lx04le's Avatar
lx04le is an unknown quantity at this point
2 Problems
Hi everyone,
I posted a while back about a grinding/creaking noise coming from my back right. It creaks when I go over a dip and the suspension compresses and creaks.grinds when i'm braking hard at low speed. I was told that this would be a wheel bearing or brakes. I still have yet to check this out myself because I haven't had the time, but a couple days ago a new problem started.
only when i'm going in reverse, when I tap the brakes, I hear a dry loud squeaking/grinding noise that I think is coming from the front. This doesn't happen when i'm going forward (there's brake pad squeak but nothing like this).
Anyone have any insight?
Thanks for any help
Old Aug 8, 2014
Re: 2 Problems
Pad wear indicator noise?
Old Aug 9, 2014
lx04le's Avatar
Re: 2 Problems
I hope that's all it is. Both noises are pretty loud and off-putting I have to get this thing up on jack stands asap. I hope I just need new brakes all around.
Also a question- on the videos for replacing the wheel bearing I see people take a punch or screwdriver and hit it with a hammer into the nut. Is that to stake it in place?
Old Aug 9, 2014
Re: 2 Problems
If you are talking about hitting on the huge nut (axle nut or spindle nut) then yes. The nuts are staked (locked in place) by smashing part of the thin lip into the keyway groove.
I use a narrow beveled punch to tap out the lock so the nut can be removed without damaging the keyway or threads,
then after installing it I use a regular chisel (blunted on the end) to put the lock back in.
The service manual says you are supposed to use a brand new nut every time you remove one FYI.
HTH
Old Aug 9, 2014
lx04le's Avatar
Re: 2 Problems
HTH
Great thanks for all the help. I'll get it up at jack stands asap to see what's going on. I'll probably have to get the rotors honed at this point though so I might as well just take it somewhere to have it fully checked out
Diznavis
Jan 25, 2002 11:25 AM
TeamStylesRacing
Jan 20, 2002 08:38 PM
delacampos
Transmission
Jan 2, 2002 02:06 PM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
Flatlander
Nov 16, 2001 05:38 PM
