Help about rims/tires
Old May 10, 2014
devkay's Avatar
devkay is an unknown quantity at this point
Hi i have a 02 civic ex coupe and the oem fit is 185/65r15. I wanted to try and stay with this size tire but all the wheels i look at recommend 195/60r15....will a 185/65r15 tire fit okay on a wheel with that recommendation? Or will it give issues/screw up speedometer/ wear the tread faster etc?
Old May 10, 2014
GolNat's Avatar
Prelude Owner
Re: Help about rims/tires
If the tire size is the same as OEM then it won't screw up your speedometer. The 195/60 will give you a bit wider tire with a slightly smaller sidewall, and will only throw your speedometer off by a small amount (if you want to go with that size). Either tire will for just fine.
http://www.tacomaworld.com/forum/tir...0r15-185-65r15
Old May 11, 2014
185/65R15 is one of the stock size tires
Old May 11, 2014
devkay's Avatar
Sorry guys what i was trying to ask was the wheels meaning rim i'm loooking at recommends the tire size 195/60r15 but i wanted to stay with my oem tire size of 185/65r15 would my oem tire fit that rim even though it's recommending 195/60r15
Old May 11, 2014
GolNat's Avatar
Prelude Owner
Yes it will fit.
TonoAlpha
Apr 30, 2015 04:21 AM
xnaron
Wheels and Tires
Mar 14, 2013 11:22 AM
rudeboyw
Feb 20, 2007 05:49 PM
civic02ex
Apr 28, 2006 10:27 PM
qwerty99
Nov 12, 2004 02:40 PM
