Brake pedal is soft
Old Jun 10, 2012
troutbum24's Avatar
troutbum24 is an unknown quantity at this point
Brake pedal is soft
First off I my wife began to complain about her brakes squealing so I decided to change her brake pads since I had them in the garage even though there was plenty of pad left (1/4") I put the new pads on that autozone gave me and went for the test drive... I could hardly roll down the driveway in neutral. Needless to say the wheels got hot fast!!! So I put the original pads back on just cleaned them up real good and now the squeak is gone. However now when driving, you have to push on the pedal for about 3 or so inches before any braking happens. So I blead the brakes on all 4 wheels but still the pedal has about 3 inches before any braking occurs. Any ideas on how to fix this? I did some research but only found 2 people bickering on how to change pads. On a side note I learned that I probably changed them incorrectly as I had my wife press all the way down to the floor on the pedal before I opened the bleed screw.
thanks
Blaine
Old Jun 10, 2012
lazlong's Avatar
Re: Brake pedal is soft
Yeah, you probably sucked air back into the system by going to the floor with the pedal. Try it again with a piece of wood under there so you don't go all the way to the floor.
Old Dec 21, 2012
tallal565's Avatar
tallal565 is an unknown quantity at this point
or u have a seized caliper. i couldn't get out of drive by letting of the brake because they were applying brakes. they also started to smoke.
Old Dec 21, 2012
krudmuphin's Avatar
I had a similar problem when my friend borrowed my car and drove with the handbrake on.
Somehow he either cause damage to the pads or sucked air into the system (I don't even understand how...) but my brakes were barely working when I started driving it again...
Old Dec 21, 2012
Stock 99's Avatar
EDIT - old thread
Old Dec 23, 2012
danwat12345's Avatar
danwat12345 has a spectacular aura aboutdanwat12345 has a spectacular aura about
Failsafe way to bleed brakes -> gravity bleed, drip drip drip and keeping the resovoir topped off. No chance of air getting in unless you let the resovoir get low during this process. Will take a while but what the hay
Old Dec 25, 2012
Nitrous1024's Avatar
Nitrous1024 is an unknown quantity at this point
I'm pretty interested in a solution to this myself, as my brakes are still spongy after changing my front brake pads and bleeding my front brake lines.
Old Jan 28, 2013
s4boost's Avatar
s4boost should not be trusted
you got air in the system bro. flush and fill
Low_Lupe
Aug 17, 2015 10:57 AM
JetsterDajet
Aug 15, 2015 08:07 AM
honda.lioness
Aug 6, 2015 11:58 AM
wootah88
Jul 21, 2015 10:22 AM
Causemo
Jul 5, 2015 06:42 AM
