Front Lower control arm bushing
Old May 2, 2012
v2famous's Avatar
v2famous is an unknown quantity at this point
I went to my Honda dealer yesterday and he said my Front Lower control arm bushing was cracked
If I buy a set on Ebay for 50usd is it just the bushings that are cracked?
And if I do it that way will I need a press still or is it just simple to swap them
Old May 2, 2012
MindBomber's Avatar
Live for the Twisties
Re: Front Lower control arm bushing
I don't know what you are referring to buying, the bushings or the complete arms.
Regardless, you need a press to install them.
Old May 2, 2012
BlueEM2's Avatar
Whachya lookin at?
You can get them out with a hammer, but you will need a press to get them back in. However, there are alternative measures that I would try first .. if I did not have access to a press.
Don't buy a cheap bushing, get energy suspensions ones and they will last you the life of the car.
Old May 2, 2012
v2famous's Avatar
Can you refer me to a website out post links possibly
I found a set on Ebay and there polyurethane
Old May 2, 2012
v2famous's Avatar
From what the dealer said the only stated "front lower control arm bushing was cracked"
That's the only thing they said and they want to charge me 400 to replace it
Old May 3, 2012
CGaud's Avatar
CGaud is an unknown quantity at this point
The dealer also told me that I had a cracked bushing... A member on here informed me that it's easier and cheaper to buy a whole new control arm (you can probably search the forum and find the post). I purchased them with the energy bushings somewhere online but it was around a year ago and I forgot which site it was. Good Luck!
Edit: It might be worth checking the suspension section
Old May 4, 2012
^ yep, remove the control arm, (hard part is only ball joint) and pop new in. et voila! you have a spare arm to press new bushings at your leisure and a working control arm in the car. it's not much expensive and much less work.
Old May 4, 2012
BlueEM2's Avatar
Whachya lookin at?
Do it yourself and change the whole control arm It is easier. I'd personally change just the bushings but I know how to remove the bushing from the arm and press in the new one. So, essentially it's up to you how big of a job you want to tackle. 400 dollars is only because they replace the whole arm and your paying a lot more for that.
Bushing should be about 40 dollars maximum and 1-2 hrs labour so around 200 bucks.
Old Jul 11, 2012
inifiniteblur's Avatar
inifiniteblur is an unknown quantity at this point
amazon has front LCA's for 50 bux.
Old Jul 11, 2012
cmiller_01ex's Avatar
cmiller_01ex has a spectacular aura aboutcmiller_01ex has a spectacular aura about
here is the easiest way to change the front bushings but like every one said you will need a prress. you take a drill and drill around the rubber untill it falls apart. then the metal part on the inside will fall out. then take a hack saw cut the outer ring from the bushing just be care full not to cut into the control arm. i did it on the part where it connects to th control arm where the most metal is. then take a hammer and screw driver bend the metal til it falls out. then press the new one in. use alot of the grease they supply and it will be done. 50 bucks ebay maybe 20 bucks in renting a space at a shop to do it or paying a guy at a shop to press it in and you have them done. its way easier than you think believe me. i just redid min. i'd buy the red energy suspension ones to that way you know they are changed. =)
Old Jul 12, 2012
EM202's Avatar
EM202 is an unknown quantity at this point
www.energysuspensionparts.com has them for $47.99, shipping is $7.99, total $55.98, much better them oem, cheaper than oem and most aftermarket (advance, autozone, etc)
Old Jul 12, 2012
palsana's Avatar
palsana is an unknown quantity at this point
I put awhole assembly of front left lca+bushings came in pre-installed for a 03 civic ex4dr sedan.
I suggest to have it installed at a shop. The work involved in removing & installing it is at best TEDIOUS.. I would rather have the car lifted and worked on. Its so much easier, convenient & faster if done that way.
BTW, i used ADVANCE AUTO AND their discounts/coupons & it did turn out real cheap.
Old Jul 12, 2012
lowlife9's Avatar
you can also rent a press tool for free at autozone and most parts stores.
Old Jul 12, 2012
BlueEM2's Avatar
Whachya lookin at?
piece of cake Use a hammer to press them if your too lazy to rent the tool.
Old Jul 12, 2012
EM202's Avatar
Only problem I had was the center on one of the bushings corroded to the bolt, so I had to cut it out and bent the frame nut back down from being turned out on my passenger front. Other than that and pressing the old shells out, this was really a quick and simple job. I also wound up having to replace the sway bar end links cuz they fell apart when putting them back together.
A bench vise also works very well for this too if available, when tight on the bushing, it wont be in all the way, just wiggle the arm a bit and it will pop right on
GolNat
Sep 10, 2015 08:25 PM
beachglass
May 22, 2015 09:59 PM
bryden13
May 18, 2015 12:22 PM
Dorval Andre
May 1, 2015 09:37 AM
bsmiley
Apr 27, 2015 01:27 PM
