Maximum Tire Size?
Old Dec 13, 2011
Rad02Civic's Avatar
Rad02Civic is an unknown quantity at this point
Maximum Tire Size?
I have a 2002 Civic Lx with stock suspension with 205/45's on a 17 inch rim right now. The tires need to be replaced and the guy at the Discount Tire shop here locally said that I could go with 225/45's as the biggest size tire that would fit. I've been checking around and reading other forums/posts and have been gathering mixed opinions/comments as to the biggest tire that would work.
Does anyone have any experience with their own Civic's with a similar issue, or any knowledgeable tire guys out there that could shed any light on this would be greatly appreciated.
Thanks.
Old Dec 13, 2011
drmcstford's Avatar
Civ ILL
drmcstford is an unknown quantity at this point
Re: Maximum Tire Size?
I would also check the miata tire calculator just to make sure you are not off in tire size by much, otherwise your mph and mileage may be out of wack.
Old Dec 13, 2011
MindBomber's Avatar
Live for the Twisties
The largest size you can fit is 215/45/17 without fender work, a tire that size won't benefit you any way unless you're swapped or boosted.
Old Dec 13, 2011
sl33pyriceboi's Avatar
youll be better off getting stickier 205/45/17 like falken azeniz or something
Old Dec 18, 2011
02carbon_civic's Avatar
02carbon_civic is an unknown quantity at this point
you can go up to 18 without work and i have seen 20's on our civic stock ride hieght jus a bit of fender work
Old Dec 19, 2011
DoveDeon's Avatar
DoveDeon is an unknown quantity at this point
Mine are 215/35/18
hondadriver95
Jul 13, 2015 09:43 PM
Genyc07
Wheels and Tires
Jul 11, 2015 05:51 PM
muttleytm
Jul 8, 2015 04:13 PM
BootyDo
Jul 7, 2015 06:06 AM
Causemo
Jul 5, 2015 06:42 AM
