front end shimmy
Old Nov 12, 2011
skeener51's Avatar
skeener51 is an unknown quantity at this point
front end shimmy
at 35-45 mph there is a slight vibration in the front passenger area. the car is a 2004 civic lx coupe. i do have aftermarket rims 18" and lowering kit, but this problem just started. please help, and hopefully it's a cheap resolve. i've spent way too much in repairs in the past month.
Old Nov 12, 2011
MelJ's Avatar
Trance Addict
Re: front end shimmy
Have you had your wheels balanced at all? Could be something as simple as that.
Old Nov 12, 2011
MindBomber's Avatar
Live for the Twisties
Check to see if your front lower control arm bushings are torn, that can also cause vibrations at speed.
Old Nov 13, 2011
civydcex's Avatar
civydcex has a spectacular aura aboutcivydcex has a spectacular aura aboutcivydcex has a spectacular aura about
You mentioned you had work recently. What was repaired? I had 2 main shaft and 1 counter shaft bearing replaced in my 5spd trans and after the dealer removed my subframe to do it, i got a wobble myself. Courious!!!!
Old Nov 14, 2011
Running Riot's Avatar
^Warranty voider
Running Riot is a glorious beacon of lightRunning Riot is a glorious beacon of lightRunning Riot is a glorious beacon of lightRunning Riot is a glorious beacon of lightRunning Riot is a glorious beacon of light
^X2 check the balance. If something is off balance youll feel the car wobbling. if you've had them balanced or feel the shimmy in the steering wheel and not the car i'd recommend you check:
1. lug nuts
2. axle nut
3. tie rods
4. ball joints
5. tire pressure
6. tire tread
7. CV axles
8. engine mounts
Old Nov 22, 2011
skeener51's Avatar
headers was the main repair.
Old Nov 22, 2011
skeener51's Avatar
edspyhill09
Jun 12, 2016 02:45 PM
Lopes101
Jun 7, 2015 08:04 PM
chuffsy
May 15, 2015 12:50 PM
pheaton
May 4, 2015 08:26 PM
GH04si
Apr 15, 2015 08:13 PM
