brake conversion list
i have gotten two different lists by searching. i know about the DIY. i cannot locate any yards that have any wrecked ep3's. i want the conversion on my 02 em2 but i got these lists. which one is correct? do i need the bearings and srs wire or not?
list 1
(1) Mudguard, R. RR. 43253-S6D-E50
(2) BEARING ASSY., RR. 42200-S5A-J01
(2) CALIPER SEAL KIT 01473-SV4-000
(2) DISC RR BRAKE. 42510-S6D-E00
(4) SCREW FLAT (6X14) 93600-O6014-OH
(2) CAP, HUB UNIT 42326-S5A-000
(1) CALIPER SUB-ASSY. 43018-S5A-J02
(1) CALIPER SUB-ASSY. 43019-S5A-J02
(4) BOLT FLANGE (10X25) 90103-SN7-003
(1) PAD SET, RR. 43022-S6D-000
(1) WIRE B, L. (E-BRAKE CABLE) 47560-S5S-E14
(1) WIRE B, R. (E-BRAKE CABLE) 47510-S5T-E13
(1) KNUCKLE, R. RR. 52210S5A-902
(1) KNUCKLE, L. RR. 52215-S5A-902
(1) SRS CABLE 57470-S5D-013
(1) SRS CABLE 57475-S5D-013
list 2
1073309 007 1 CALIPER SUB-ASSY., R. RR. 154.51
1073310 008 1 CALIPER SUB-ASSY., L. RR. 154.51
1082874 006 2 DISK, RR. BRAKE 35.66
1095008 028 1 MUDGUARD, R. RR. 15.83
1095009 029 1 MUDGUARD, L. RR. 15.83
1073334 001 1 KNUCKLE, R. RR. 143.28
1073335 002 1 KNUCKLE, L. RR. 143.28
1095011 005 1 WIRE B, R. PARKING BRAKE 25.54
1095012 008 1 WIRE B, L. PARKING BRAKE 24.08
list 1
list 2
Re: brake conversion list
car-part.com
call any place that has the brake calipers and ask them if they also have the rear knuckles and hand brake cable. any good junkyard will know what your are talking about if say you need the rear knuckle and whole rear brake assembly. or you could call up to canada and get it off an 01-05 acura el.
i got my setup on ebay years ago for far less than most people were paying for them on the forums or scrap yards. just throwing it out there, because getting all new parts is going to make it a really expensive conversion..i'd just keep searching around before trying to get these parts new. you're bound to find something sooner or later.
^x2
I found a junkyard in canada via ebay called them up and got everything for dirt cheap. I paid $350 canadian shipped and at the time that was like $150-$175 US
ok well i will try all that but i was going to do k20 swap after i get back from tx, i just did the brake upgrade from dezod. wanted to do this brake swap and put same rotors and pads that i just got.
Or, if you want to stick with the 4 lug, get the rsx base setup and buy the 02-03 ep3 hubs from majestic honda. Then you have all wheel disc brakes that bolt up and use stock axles that are 4 lug.
I have a 2002 Civic coupe I want to do the same thing with. Do you know the name of Canadian junkyard you got them from?
Thanks
Kyle
OptimisticWay
Jul 10, 2015 04:31 PM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
Causemo
Jul 5, 2015 06:42 AM
