tire size ?
Old Jan 16, 2009
jra04em2's Avatar
jra04em2 is an unknown quantity at this point
tire size ?
i have a lowered 04 civic coupe with 18s on it and i was told i could only run 215 35 18 is that true or can i run a more normal size tire without rubbing let me know cause i need a new set bad let me know asap
thanks
jamie
Old Jan 16, 2009
mrtrinh's Avatar
mrtrinh is a glorious beacon of lightmrtrinh is a glorious beacon of lightmrtrinh is a glorious beacon of lightmrtrinh is a glorious beacon of lightmrtrinh is a glorious beacon of lightmrtrinh is a glorious beacon of light
Re: tire size ?
you need to provide more information... currently how low are you now? a picture would be nice as well
Old Jan 16, 2009
sl33pyriceboi's Avatar
Re: tire size ?
depends on how low you are, ur offset of ur rims, the width of ur rims, ur current tires.....etc.
and yes, 215/35 will most likely rub.
go with sticker tires, there is no point for you going wider than 205 on ur civic... ur handling isnt that great, so there is no point in getting the extra 10 (from 205 to 215)...
Old Jan 16, 2009
adnoh0002s's Avatar
adnoh0002s is an unknown quantity at this point
Re: tire size ?
i have an '03 civic lowered 2" and i'm running 19's w/ 215/35/19 tires and still no rubbing. offset is 40. you should be fine with 215/35/18 as they have a slightly smaller overall diameter compared to the 215/35/19. you could also go with 215/40/18 tires but i don't see the point as they tend to be more expensive and make the rims looking smaller.
if you want my opinion, i would stick to 215/35/18.
Old Jan 16, 2009
lilmidget08's Avatar
lilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond repute
Re: tire size ?
why run 18's??? news flash civics are slow (stock) and even slower with wheels that big on them.
Old Jan 17, 2009
Re: tire size ?
each person has different set of values. he could care less about the horrible performace.....but as long as he's got them 18" dubs on his civic....... YOUUUUUUUU KNOOOOOOOOOOOOOW~!
Theshwartz35
Jul 17, 2015 11:13 PM
Genyc07
Wheels and Tires
Jul 11, 2015 05:51 PM
muttleytm
Jul 8, 2015 04:13 PM
BootyDo
Jul 7, 2015 06:06 AM
Causemo
Jul 5, 2015 06:42 AM
