215/35/18 in the front and 215/40/18 in the back?
Old Mar 20, 2008
carter's Avatar
carter is an unknown quantity at this point
I tried to search up an answer I guess I didnt searth with the right key word or somthing. Is that possible to do?
I know the back wheels if the cars not lowerd shouldnt have a problem with tire size as much as the front since they only sping forwards and backwards???
Old Mar 20, 2008
svtec's Avatar
svtec is an unknown quantity at this point
Re: 215/35/18 in the front and 215/40/18 in the back?
all your doing is putting a thinner side wall in the front and a thicker one in the back. i would not do that i have 215/18/40 tires on my ride and no problems. are you trying to put wider tires in the front?
Old Mar 20, 2008
redrocket600's Avatar
redrocket600 has a spectacular aura aboutredrocket600 has a spectacular aura aboutredrocket600 has a spectacular aura about
Pointless on a FWD car...not to mention it will screw with your handling. It won't look right either...
Old Mar 20, 2008
mgsjester's Avatar
mgsjester is an unknown quantity at this point
redrocket600 is correct...and also, 18's are way to big to put on a civic but that is just my opinion. I think 16's or 17's look best on a 7th gen.
Old Mar 20, 2008
Envy's Avatar
Diamond Member
Envy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of light
yes its doable. what are you going for? a softer ride?
Old Mar 20, 2008
carter's Avatar
^^^ Yeap Evny thats what im going for, because the front you can slow down and avoid the bumps but the back always hits that unexpected bump right after you steer away from the front.
THe suspension gets softer as the car gets heavier and from what i know the civic is not a 50/50 weight distrubted front to back right? So the front wouldnt be as bad as the back would so the Thicker tire(not wider) would soften the ride no?
Old Mar 20, 2008
sl33pyriceboi's Avatar
if u get 18" ur gonna want 30 sidewalls
and 215 might be too wide, you'll rub...
get 205/30/18......that should be almost exact oem spec...
and dont think ur gonna lose any "performance" from losing 10 (from 215 to 205) cuz ur car isnt even suited for handling...
its a pointless goal if thats what you were mildly aiming for.
if u wanted handling, you should get some koni/yellows and some light rims with a 45side wall
Old Mar 20, 2008
carter's Avatar
No im not about teh handling I just want to get back some ride quality (i know there 18s bla bla) Anything helps right.
215 Might rubb? Oh I shore as hell hope not because thats what WheelsNext sent me. Id hope they'd know what they were doing when they sent me thoes becasue the guy who helped place the order was also a Civic driver and said these would go perfect.
Old Mar 20, 2008
svtec's Avatar
cater, the 40 series tire is a great look for the 18" rims on our car just go with them. the 35 is even thinner i went through the same thing trying to decied what tire to get but you will be happy with the 40 all the way around. i love the way my car looks.
Old Mar 20, 2008
phuviano's Avatar
Slowest 7thgen in the GTA
I'd go with 40's all around. You will have to rotate the tires eventually. It'll look so weird with thicker tires on the front, and thinner tires on the rear when you do eventually rotate the tires.
If you are not lowered, I doubt you'll rub with 215's.
Old Mar 20, 2008
Civic_Racer9's Avatar
(SnOwBoArDeR | FoReVeR)
why would u wanna put 18s on a civic anyway?
Old Jun 10, 2008
K20A_Wanabe's Avatar
K20A_Wanabe is an unknown quantity at this point
To me there is no other size to put on a 7thgen civic
And
I'm lowered 1.3" with 215 and no problems
Old Jun 10, 2008
buckshizzo's Avatar
buckshizzo is a jewel in the roughbuckshizzo is a jewel in the roughbuckshizzo is a jewel in the rough
Go with the same size all the way around. Pointless to mix sizes on a civic.
Old Jun 10, 2008
Unevolved's Avatar
Rough, Tough, Real Stuff.
Unevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to behold
I guess that depends if you wanna go fast or not.
Old Jul 4, 2008
xschizx9's Avatar
xschizx9 will become famous soon enough
yea.. i'm on 215 18" inch wheel.. can't remember the sidewall off the top of my head, but i don't have any problems with rubbing or anything... I'm lowered on progress coilovers...
and I"ve had 17"s they just didn't look right so I went to 18's.
Old Jul 5, 2008
Tokoyama's Avatar
Tokoyama is an unknown quantity at this point
if your driving normally 215 shouldn't rub unless your completely slammed. the only time it might rub is if your driving aggressively or spiritedly on say a mountain run
Old Jul 5, 2008
CivicFreak03's Avatar
CivicFreak03 has a spectacular aura aboutCivicFreak03 has a spectacular aura about
215/40/18
Old Jul 8, 2008
qijian's Avatar
so im guessin with tein s techs, with 215/40/18 wont rub?
Old Jul 8, 2008
Not sure I have Eibach Pro-Kit and I have a finger and a half gap in the front and a two finger gap in the back....I know S-techs are lower so it will be close with a 40 series tire....
Old Jul 9, 2008
adnoh0002s's Avatar
adnoh0002s is an unknown quantity at this point
i'm running 19's w/ 215/35/19 tires on my 2002 sedan with a 1.75" drop all around and i don't rub.
215/35/19 ^^
Old Jul 9, 2008
tuningmycivic's Avatar
tuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to all
what's the width and offset on those wheels? cause in the end, those two things will have more to do with whether or not you rub than whether you run 17, 18, or 19 in wheels....
for the record though, 215 on 18s should be fine, as long as he's running less than a 9 inch wheel and no crazy low-positive or even negative offets
Old Jul 9, 2008
Factory struts?
Old Jul 9, 2008
qijian's Avatar
so im guessing if i run a rim that is 18x7.5 lowered on s techs with tires 215/40/18 , i dont think i'll have trouble with rubbing then? and just for opinions, do you think a 7th gen coupe with 18's without a lip kit will look funny? still debating....
Old Jul 12, 2008
Curiouz_G's Avatar
Curiouz_G is just really niceCuriouz_G is just really niceCuriouz_G is just really niceCuriouz_G is just really nice
225/45/16 on Advan SA3R's and dropped on Koni Yellows/GC's. I dont rub at all. On the rear, its a different story... rolled fenders FTW
Old Aug 18, 2008
HondaLuver's Avatar
Its a celebration bitches!
i ran 215/40/18 for a while, no rubbin... now i run 235/40/17 no rubbing
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
crowtoo
May 11, 2015 06:50 PM
Thriftmaster
Vancouver
Apr 28, 2015 06:02 AM
GH04si
Apr 15, 2015 08:13 PM
DJNuTzSaK
Nov 13, 2001 03:27 PM
