Tire sizes for 16 inch tires (search did not yield anything)
Rep Power: 0 Tire sizes for 16 inch tires (search did not yield anything)
Hi there I am planning to run
a 16X7 Work Emotion replica
I was wondering what options do I have with tires
I would like to now what is the widest tire I can run on this?
The typical size I find is 205/45/16
but wonder is there any other wider size tire I can run?
my car is lowered 2.0 Inches front and 1.8 rear, I have Tein Full-coilovers
thanks
thanks
Rep Power: 213 Re: Tire sizes for 16 inch tires (search did not yield anything)
https://www.civicforums.com/forums/4...ub-y-drop.html
Check the forum stickies for good info to. If you've running more negative camber you can go wider, but your tires will wear fast. If you've got camber corrected, I really wouldn't go over 205. Offset is important to.
Some helpful tools:
Tire size: http://www.miata.net/garage/tirecalc.html
Offset: http://www.1010tires.com/WheelOffsetCalculator.asp
Some helpful tools:
i got 205/50/16.. i think its the perfect size for 16s. im pretty slammed and im tucking the 16s a lil. PM me if you want a picture.
1 Post
Rep Power: 328 Re: Tire sizes for 16 inch tires (search did not yield anything)
you can go 215/50/16. which is basically stock spec. that what i have.
as long as ur not slammed u wont rub. (i have no finger gap in front and in rear. my front rubs and my rear doesnt.
i also had to roll my fenders.
NightKids2
12-08-2001 05:50 AM
