DIY Brake Pad Install
Old Nov 17, 2007
highwayman's Avatar
highwayman is an unknown quantity at this point
i'm planning on doing my 1st brake pad install on my '04 civic. i bought the OEM pads and a little tube of grease came with them. what/where do i use that. is it anti-squeak compound? also, a DIY sticky for pad/rotor replacement similar to the one for drums/shoes would be nice for newbs like myself. thanks.
Old Nov 17, 2007
rutscivic's Avatar
rutscivic is an unknown quantity at this point
Re: DIY Brake Pad Install
hey.
the grease is molycoat. You put it on the back of the brake pads where the caliper and cylinder will be contacting the brake pad. I usually jus brush it on the whole back of the brake pads. Ok, to start take of the wheel. You will see 2 -14mm (i think it a 14mm) bolts ON THE TOP AND BOTTOM OF THE CALIPER. loosen the bottom bolt and remove it. I would buy some high temp grease or something to rub on the bolt you removed (the slider) to protect it from seizing in the future. Then take the caliper and swing it up off of the pads and rotor. remove the pads and install in reverse order. Hopefully this works out for you...its only ONE bolt! Good luck and hope you get em..Should only take you 20mins, once your wheels are off. GOOD LUCK!
Old Nov 17, 2007
ultimatetuner10's Avatar
Technical Assistant
ultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond repute
Originally Posted by rutscivic
hey.
you forgot a few things
1. you have to reuse the little metal sheets that are "clipped" to the old brake pads
2. you have to get the caliper cylinder back in to do this
1. take off the brake fluid reservour lid under the hood
2. get some vice grips or something of the sort
3. gently push the cylinder all the way back in...it will resist but do it smoothly dont try to jam it in there by hitting it
also dont let the caliper hang from the line its on...instead, put it behind the rotor so it sits in that little nook and that way you are free to work
Old Nov 17, 2007
TRIZ's Avatar
From the main page forum listing go down to 7th gen section - and click on DIY articles. That where I found this.
https://www.civicforums.com/forums/1...d-install.html
Old Nov 17, 2007
rutscivic's Avatar
ultimatetuner you are right...but the new OEM pads come with the new metal shims...but i did forget pushing the cylinder back in ...it was early
Old Jan 11, 2008
highwayman's Avatar
does the grease go between the pad and the metal shim or between the shim and the cylinder???
Old Jan 11, 2008
Boilermaker1's Avatar
Jap-Euro Fusion
There's DIYs in the 7th gen forum.
Star1967
Jun 8, 2015 04:23 AM
masongap
May 26, 2015 07:55 PM
rhvic
May 22, 2015 03:06 PM
bsmiley
Apr 27, 2015 01:27 PM
