brake proportioning valve
Re: brake proportioning valve
ep3's dont have proportioning valves. it's integrated into the abs/electronic brake control.
i always thought a proportioning valve distributed fluid flow to all 4 brakes, a 4 way joint still only has 2 inputs and 2 outputs, and if youve ever held one in your hands, youd see that the two sides never meet. then again, i suppose if you have an EX with abs, you could use the ep3 4 way to flow more fluid to the rear discs, but according to the swap thread, the stock abs modulator compensates automatically.
7thgensurvivor
38
Aug 29, 2015 11:50 AM
mistermenphis22
Jul 13, 2015 04:43 PM
McLean
Jun 13, 2015 10:32 AM
1990, 2000, 4040, 92, 94, brake, civic, electronic, honda, install, proportion, proportional, proportioning, sale, valve, valves
