DC5 rear discs??
DC5 rear discs??
ok so i was looking around an rsx forum and i see somebody selling dc5 rear calipers and he says itll fit 02-05 civic si. so im wondering if they will fit my em2?
and if so is there other parts from dc5 that will fit for a rear disc conversion (besides brake lines) such as knuckles? i mean ppl do 5 lug swaps so im assuming the knuckles will fit unless the struts have to be swapped too. any help is appreciated! keep in mind i just want to do a rear disc conversion not a 5 lug swap
thanks
thanks
Pwning Noobs 24/7
Re: DC5 rear discs??
your gonna need to do a 5 lug swap other wise the knuckle and what not will not fit...im pretty sure you also need DC5 lower control arms as well
i was just wondering if uld have to swap out the whole suspension or not to use dc5 knuckles. i dont want to do a 5 lug swap tho.
just wonderin about calipers now...
"mmmBAHHHH" - vtec y0
the only real caliper upgrade you can do for our cars is the front calipers offa a intergra type R which is simply a bigger one piston. boilermaker did it. do a search he posted a diy
Ashho-san 7thgen Ninja
well i know you can swap the rear discs from an 02-05 SI, and if the rear calipers from the dc5 fit the si, i dont see why they wouldnt fit the em2, assuming you did the rear disc convesion already
yeah this is true. but i was just talking about the fronts. id love to find a way to get the dc5 itr 4 piston brembos to work on my car. hmmm maybe i should pick up a set and do some custom fabbing
haha if you got the money to pick up some brembos and start cuttin to see what you can do, then you should just do the lug conversion, it would be easier
h4ldol
Apr 24, 2017 08:16 PM
Sep 27, 2015 11:33 AM
hatch90
Sep 3, 2015 08:45 AM
