steering wheel shaking at 65mph
Old Feb 8, 2007
EastBayStuntN's Avatar
EastBayStuntN is an unknown quantity at this point
i been getting lazy to get this problem fixed cause i couldnt figure it out. im running 205/45/17 tires that were mounted and balanced with brand new tires/rims at wheel works, eibach sportline lowering springs, koni yellow struts, and got an alignment done right after. now everytime im driving 65mph, my steering wheel vibrates constantly. and whenever i brake to slow down from a high speed (80mph), it would vibrate again.
my guess was that i may need to rebalance my wheels?
edit: i forgot to mention that my rims dont have any of those wheel weights like what the OEM rims uses.
Old Feb 8, 2007
ohsnapsjay08's Avatar
ohsnapsjay08 will become famous soon enough
did you get a new brake disc/pad? if so, that could be one of the problem specially if it wasnt ceramic. but it will go away eventually, if not then make sure to check your tierod and all that.
Old Feb 8, 2007
FreedomEagle's Avatar
FreedomEagle has a spectacular aura aboutFreedomEagle has a spectacular aura aboutFreedomEagle has a spectacular aura about
ya if its shaking when u brake its your brakes probably. i have sportline springs almost the same exact size tires in falken and im an 03 coupe and havne't had that problem and have had same springs for a year and almost a half
Old Feb 8, 2007
kasimmmmm's Avatar
it could be mounting and balancing of tires not done rite, bent wheel, or alignment.
Old Feb 8, 2007
PennyKnotOff's Avatar
i had the same problem but mine turned out to be a warped rotor
Old Feb 8, 2007
CuRiOuSfIsH's Avatar
Back From The Banned!
does it have any little weights at all?
Old Feb 8, 2007
probably means it has tape weights instead of the clips
Old Feb 9, 2007
04civic07's Avatar
Living Life Turn After Turn
04civic07 will become famous soon enough04civic07 will become famous soon enough
if you're braking and it vibrates THEN it's is your brakes..... if you are just cruising w/o braking and it vibrates.... it's somthing else.... maybe BOTH haha good luck
Old Feb 9, 2007
when cruising at 65mph ish, it vibrates a little but i still have full control of the car. i did get my brakes resurfaced AND pads changed at big-o tires around 36k miles, im at 42k right now. i had the mechanic put on the best pads they had (total of 4).
Old Feb 9, 2007
gmag21's Avatar
gmag21 will become famous soon enoughgmag21 will become famous soon enough
same thing happens to me, i have 17's too
Old Feb 9, 2007
^were you able to fix the problem or still running like that?
Old Feb 9, 2007
slickstarnz's Avatar
slickstarnz is an unknown quantity at this point
I had the same problem, took it to the wheel shop got them rebalanced and problem solved.
Old Feb 9, 2007
Honda_Inspired's Avatar
Honda_Inspired is an unknown quantity at this point
Are you using any hubrings? hubcentrics? I say that because most aftermarket rims do not have the same hub diameter as stock, which throws off a few centimeters when mounting the wheel on the hub. Happened to me once, I bought some plastic hubrings from discount tires and it went away.
Old Feb 9, 2007
Devani's Avatar
Devani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond repute
put stock rims and tires if you have them....
if you have same problem then..
if the problem is gone...then..
Old Feb 10, 2007
honda inspired, i do have hub rings. my wheels were 4 lug universal =\
ill look into a rebalance if my lifetime warranty is still active at wheelworks
Old Feb 10, 2007
ragingSPAM's Avatar
I just burnt my tongue
well if you have just gotten the wheels balanced than it could be warped rotors, defective tires, defective rims....wheel balancing can be screwed up rather easily so go get it re balanced and if it persists than try on other wheels and see if it keeps doing that
GotSiR
Jun 23, 2016 04:06 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
kaashifv
Interior
Jul 27, 2015 05:28 PM
breanna_17
Jul 21, 2015 04:01 PM
qlitten
Jul 21, 2015 03:12 PM
