205/45 vs 215/40
Old Oct 6, 2006
bluestreak's Avatar
bluestreak is an unknown quantity at this point
205/45 vs 215/40
Which would you buy - i've got 215-45-17 now and they slightly rub in the back with some neg camber. Well since it's dropped, i need new tires and want some little extra room in the rear fenders. Which tire size is better?
and how much different is the heights? I know profile is percent of width, but don't feel like doing the math?
Old Oct 6, 2006
simplicated1979's Avatar
simplicated1979 will become famous soon enoughsimplicated1979 will become famous soon enough
hmmmmm....you need to stop being lazy...
Old Oct 6, 2006
HondaLuver's Avatar
Its a celebration bitches!
i'd tell you to stay with the 215/45 but its not like i know anything... just because im running 17x8rims and 225/45 tires...
Old Oct 6, 2006
GOTSPRINGROLLS's Avatar
Super Member
GOTSPRINGROLLS is an unknown quantity at this point
I'm running 215-40-17 and have no problems.
Old Oct 6, 2006
bluestreak's Avatar
^ nice, what drop if any, and what brand of tires?
Old Oct 6, 2006
bluestreak's Avatar
if I can do math correctly, seems like the 205/45 has slightly taller sidewall which = better rim protection in these shitty new england roads....BUT I lose the 10mm of width, which I suppose is worth it....any comments?
Old Oct 6, 2006
klectic's Avatar
klectic has a spectacular aura aboutklectic has a spectacular aura aboutklectic has a spectacular aura about
im now running 215/40/17 (nexen) and have problems at all
dropped around 3 inches or so (tucking in the rears)
i was running 215/45/17 (falken) prior and had no problems with those either. my rear is tucked in, and have very very minimal space between my fender and my tire.. i could roll my fenders (or got 205's), but i dont want too.. but they never touch anyways..
the difference between a 40 and 45 is maybe just half an inch or so.. and when i first got my 40's on.. i liked the look of 45's better... but now im used to the 40 profile..
why dont u just roll ur fenders? 215 to 205 won't be too bad of a diff anyways..
Old Oct 6, 2006
Colombian4Lyf's Avatar
Colombian4Lyf is an unknown quantity at this point
I ran 215/35 with 18inch with no rubbing
Old Oct 6, 2006
CenZ's Avatar
PWIT
i got 205/40/17 and i have no problems and im dropped like 2" maybe more
im on stock 15s right now and im tucking so i think its more than 2"
Old Oct 6, 2006
DaddyFatSacks's Avatar
DaddyFatSacks is an unknown quantity at this point
I like a 215/40 I like that low sidewall look, i think 45 look like truck tires.
Old Oct 9, 2006
bluestreak's Avatar
yeah, my damn rim offset is the issue - just looking for tire size recomondation, I had 205-40-17 w/o drop and there was mad wheel gap, so I think i'll go w/ 205/45/17
Old Oct 9, 2006
jamie_civic's Avatar
jamie_civic is an unknown quantity at this point
id go with the 45 profile...either 205 or 215.
Old Oct 9, 2006
EM2 Bluez's Avatar
EM2 Bluez is an unknown quantity at this point
Think of it this way. . . If you decide to get another size other than 215-45-17 you have to think of what tires are made in those size bcause im pretty sure thats not a common size to be running. . . maybe 205's yes but i doubt 215-40 just my 2 cents.
Old Oct 9, 2006
bluestreak's Avatar
tirerack has many tires at these oddball sizes that I didn't even know existed
Old Oct 9, 2006
EM2 Bluez's Avatar
Yes that may be true that they do have tires but what are the chances of getting good decent tires? and how well is your speedometer? Most of the tires in that size are really good but really expensive, so if your looking for decent tires your not in luck its either really good or really bad. In My Opinion
Old Oct 9, 2006
bluestreak's Avatar
http://www.tirerack.com/tires/Compar...=9&RunFlat=All
Here's the link, mad tires
Old Oct 9, 2006
bluestreak's Avatar
and here's 215-40-17
http://www.tirerack.com/tires/Compar...13&RunFlat=All
Old Oct 9, 2006
bluestreak's Avatar
higher profile, right? i'm goin w/ 205-45-17 for sure
Old Oct 9, 2006
HondaLuver's Avatar
215/45 ftw
Old Oct 10, 2006
bluestreak's Avatar
not sure, but I've had 205-40-17 and 215-45-17 on the same rims
Old Oct 10, 2006
billiardini's Avatar
billiardini will become famous soon enoughbilliardini will become famous soon enough
im running a 205/40/17 on 2.5 inch drop... Tires tuck in perfectly,, no need
to roll fenders
Old Oct 10, 2006
bluestreak's Avatar
my fenders are already rolled, so I can fit the 205-45-17
Old Oct 10, 2006
LiKEaFeRiO's Avatar
Your alignment makes a difference too.
I'm sure everyone here has alignment specs that are within "safe range" which could be a range of one degree or more.
That makes a big difference on rubbing issues.
I went from 205/40 to 215/40 and started having rubbing issues in the back.
-1.5 camber on both sides solved that problem.
Old Oct 10, 2006
bluestreak's Avatar
yeah, neg camber owned two tires, so quickly and so bad that there was the steel radials showing through, I couldn't believe it
Old Oct 12, 2006
EM2 Bluez's Avatar
For that to happen it could possibly be your Toe also not just camber. I'm pretty sure your rims are 7 inch width or 7.5 either way they can fit. Might be stretched a lil but it can fit.
phuviano
May 10, 2005 01:32 AM
itskalvin
Apr 5, 2005 04:05 AM
stroked_monkey
Feb 24, 2005 10:43 PM
hondah1
Nov 4, 2002 11:46 PM
impetigo
Oct 23, 2002 02:48 PM
