brakes question
Old Mar 13, 2002
AFlyer's Avatar
AFlyer is an unknown quantity at this point
brakes question
if you upgrade to big brakes in the front and you have ABS, will the ABS still work with the new pistons and rotors? also, will ABS work at all with a drum to disc conversion in the rear? i ask because i want to do the brake conversion on my EX, but if it kills the ABS it's not gonna happen for me.
Old Mar 14, 2002
AFlyer's Avatar
c'mon people, anyone know? please?
Old Mar 14, 2002
02CarbonCivic's Avatar
02CarbonCivic is an unknown quantity at this point
Did you try e-mailing AEM and asking them.... just a thought
Old Mar 14, 2002
solar's Avatar
solar is an unknown quantity at this point
Iwould think it shouldn't be a problem, the sensor for ABS only senses if the wheels lock up, it shouldn't matter about the size.
I have always said that the 2 most important things on a car are the tires and brakes, make sure you have someone qualified to install the brakes, the last thing you want is a brake failure.
Old Mar 15, 2002
aldini's Avatar
aldini is an unknown quantity at this point
I couldn't agree more... My first car (it was used) After I signed the pink slips I went straight to Sears and got me new tires... Then I got me new brakes.. Hey the tires is the only part of the car keeping you in touch with the ground...
Old May 25, 2002
tummyboy's Avatar
tummyboy is an unknown quantity at this point
Well it should not matter because you dont need special calipers for ABS because ABS consists of wheel sesnors a special master cylinder and a computer that controls the brakes but thats about it as far as the rear not working that is quesionable because you would have to get the wheel sensors installed some way on it other wise you wont have ABS in the rear. But I would definetly ask AEM how that works with the wheel sensors
Old May 25, 2002
2cute's Avatar
2cute is an unknown quantity at this point
I may sound stupid right now but as far as I know there is no conversion for rear drums to discs on the back. Am I wrong? I know Willwood doesn't have it yet.
Old May 25, 2002
SilverSurf's Avatar
SilverSurf is an unknown quantity at this point
If you do the big brake upgrade in the front, ABS will still work. However, there is no ABS to the rear drums. Also, there is no conversion kit out for the rear drum to disc for the 7th gen vics yet. Hope that helps ya. [IMG]i/expressions/face-icon-small-cool.gif[/IMG]
Old May 28, 2002
tummyboy's Avatar
What about the AEM conversions I might be wrong but I thought they came out with a conversion kit
Old Jun 2, 2002
itzwolf's Avatar
itzwolf is an unknown quantity at this point
The big brake upgrade is said to be fully compat. with ABS...
Old Jun 2, 2002
CivicVTec's Avatar
CivicVTec is an unknown quantity at this point
well...before u buy the brake system you need to look if the system is ABS compatible, most companies like Wilwood, Brembo, AEM, HP Racig are all ABS compatible.
Old Jun 2, 2002
blackcivic07's Avatar
blackcivic07 is an unknown quantity at this point
i say screw abs, as long as your brakes work, who cares? i hate abs brakes, they suck in the winter, sure you don't go off to the side, but you don't stop either!! stupid things have almost cost me my car more than once, i went no abs for a few years before and never had any problems, i just did a lil pumpin when i was neccessary, ahhh anyway just thought i'd put in a post...peace[IMG]i/expressions/beer_yum.gif[/IMG]
Old Jun 3, 2002
SilverSurf's Avatar
Tummyboy, the AEM Rear Disc conversion kit is out for the 6th gen vics, and I think another gen, but not ours yet, you can check the AEM site, click on Big Rotor Brake kits, and then see the applications, none is out for the 7th gen vic, you may be confusing it with the Four Piston caliper kit, which is still only for the front upgrade.
7thgensurvivor
38
Aug 29, 2015 11:50 AM
masongap
May 26, 2015 07:55 PM
bsmiley
Apr 27, 2015 01:27 PM
viper775
Dec 9, 2001 10:52 PM
