Rust?? In Arizona???
Old Aug 22, 2006
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
Thumbs down Rust?? In Arizona???
Other then painting my drum breaks...
how do I get this rust off???
Thanks as always guys!
Old Aug 22, 2006
DDragon7's Avatar
Since its bare iron, its gonna rust unless you paint it.
Old Aug 22, 2006
02BLKCIVIC's Avatar
Well ****!
Could you point me in the direction for the DIY on painting my calapers & drums please?
Should I sand down the drums first???
Old Aug 22, 2006
DDragon7's Avatar
Yeah, sand it the best you could (a wired brush mounted on a drill helps alot) then, I would recommend using dupicolor caliper paint, I should have done that from the beginning than using regular high temp paint. Dupilcolor caliper paint kit is a brushed on paint, so its easier and less masking required and it has ceramic compound of some sort which will help it last longer with brake dust.
Old Aug 22, 2006
02BLKCIVIC's Avatar
Reped you sir!^^^
Thanks!
Old Aug 22, 2006
Valdeezy's Avatar
Valdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to all
ok well what about the disk brakes up front. After it rains out here mine get rusted all the way around. How do I prevent that?
Old Aug 22, 2006
02BLKCIVIC's Avatar
I just have some at the "top edge" around the front rotor.^
Or are you talking about the "hub" it self valdeezy?
Old Aug 22, 2006
Valdeezy's Avatar
no Im talking around the rotor itself up on the front brakes. I have rust around the whole rotor itself. Do I just spray disk cleaner on them or do I have to have them sanded down?
Old Aug 22, 2006
02BLKCIVIC's Avatar
hmmmmm! wierd!
"That" rust, like after raining & what not
always comes off after the first red light I hit.
hmmmmmm, If I had to guess Id say your gona have to sand it.
But maybe someone can confirm that...
Old Aug 22, 2006
tuner04civic's Avatar
spell check pwns you
if its on the rotor where the brake pad touches it should burn off when you start driving. and i had issue with rust too, i had painted it blue but now black. worked out well for me, good luck
Old Aug 22, 2006
DDragon7's Avatar
I didnt do anything to the outer edges of the disk, since I cant really see them, but I did paint the centre ring of the disk by the bolts.
Thanks for the rep and as usual, I rep others back.
Old Aug 22, 2006
FALKEN's Avatar
Civicforums Junkie
i have rust too...im going to paint mine the next time i do a rotation
Old Aug 22, 2006
zen_master's Avatar
damn..you guys are talking about rust in rotor and drums??
lol........come up here and you'll see the real thing.....
that's nothing to talk about up here...lol!
Old Aug 22, 2006
02BLKCIVIC's Avatar
I’m good Zen.^
This rust alone pisses me off!
I can’t imagine having rust "on" my car.
Id **** a brick!
Old Aug 23, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
Its iron, no matter what you do to it, its going to rust. It gets hot, heat nukes the paint (even the high temp junk). Just come to grips with the fact that brakes are functional, not pretty, and let them do their thing.
If it really bothers you that much, buy lots of paint cans, cuz you'll be painting them every time it rains.
Old Aug 24, 2006
02BLKCIVIC's Avatar
thanks sir!^
Mad Dog Tannen
Oct 19, 2016 08:12 PM
twd000
Oct 4, 2015 12:52 PM
Sep 27, 2015 11:33 AM
General DIY
Sep 25, 2015 08:02 PM
Bikergofast
Sep 12, 2015 01:36 PM
