Funny feeling on brakes..
Old Aug 4, 2006
CivicMexicano's Avatar
El Pinche Turbo Mexicano
CivicMexicano is an unknown quantity at this point
well i have a week with my new brakes changed rear drums for discs, also swaped to ss lines, installed slotted and drilled rotors and some axxis ultimates all around...
my quetion is, how long should they take to settle in, also i feel a slight vibration and the end of braking (when speed is about 20 mph or less), could the rotors be lose?
also my system had a lot of air, i mean a lot, we bleed the twice and there was still some air coming out of the lines, we didnt bleed a third time cuz it was kinda late, what can cause so much air to be in the brake lines??
also when installing my pads the rear piston was a bitch compress could it be cause no fluid was in them? i had bought them several months back and didnt install them until now....
Old Aug 4, 2006
i would have it checked again to be sure, but there is a break in time.
Old Aug 4, 2006
skipbarber's Avatar
vibration during braking could be rotor/pad run-out. try getting your rotors resurfaced. bleed the lines again, you dont want ANY air in them at all.
Old Aug 4, 2006
So even if the pads and rotors are new, the rotos could need resurfesing?
Old Aug 4, 2006
Rennen's Avatar
New Mod on the Block
are slotted and drilled rotors resurfacable? sorry for the n00b question...
Old Aug 4, 2006
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
You have ABS?
Old Aug 5, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
Are these slots and holes cast in? or machined in? If they're machined, you probably feel all the slots and holes, which is causing the vibration.
If you bled them twice and still have air in the lines, you're either not bleeding them properly, or you have a leak.
Old Aug 6, 2006
Yes my car has ABS, so it would be a good idea to have them resurfaced...
Old Aug 6, 2006
just was thinking is it like a little quick shimmy in the pedal when you hit the breaks?
Old Aug 6, 2006
cdmx's Avatar
Try gravity bleeding over night for your air in the lines issue
and check that all your components are on right and "tight"
Are these discs new?
No it could cause damage to the bit
thebmillz
Electronics
Oct 2, 2015 08:38 PM
Dave Brabant
Sep 27, 2015 09:43 PM
srtlat
Sep 17, 2015 11:02 PM
BBrosario
Sep 17, 2015 07:51 PM
Juanb24
Sep 15, 2015 12:39 AM
