Steering Wheel Shake
Old Jul 10, 2006
half_n_half17's Avatar
half_n_half17 is an unknown quantity at this point
I'm pretty sure I know the answer to this question but I though I'd ask the experts before I sent my car to the shop...
I recently swapped wheels with my g/f cuz I had a long road trip and she's got some nice and quiet touring tires. When I got home and put my tires back on I noticed that my steering wheel now has a shake in it when I'm going faster than about 65... This wasn't there before I swapped the tires and I'm thinking that one of the wheels is out of balance. Question to you guys is will having my tires balanced fix this vibration?
Old Jul 11, 2006
NOTORIOUZ's Avatar
NOTORIOUZ is an unknown quantity at this point
of course
i have my tires balanced after i got alignment and it rides smooth as a babys ***. so Yes
Old Jul 11, 2006
lewal's Avatar
lewal has a spectacular aura aboutlewal has a spectacular aura aboutlewal has a spectacular aura about
yeah, i had the same problem w/ my old car... at 85mph or higher, the steering wheel would shake. You need to balance your tires and get an alignment if that doesn't solve the problem
Old Jul 11, 2006
InanimateCarbonRod's Avatar
InanimateCarbonRod will become famous soon enoughInanimateCarbonRod will become famous soon enough
You probably put the wheels/tires that was on the back in the front and vice-versa. I rotated the tires on my wife's car and the steering wheel started to shake because some uneven wear from the back tires (the new front tires) was causing the shaking. When the tires were in the back, the vibration was undetectable.
You should either swap your current fronts to the back (and back to front) or get new tires.
Old Jul 18, 2006
burke420's Avatar
The World Is Yours!
one problem could be that you over-torqued your lug-nuts, mine were done too-tight, and it was a horrible ride.
2.) you could have a bent wheel
3.) tire bald, flat-spot
4.) out-of-balance
5.) bad-tire, separation on tread.
those are acouple common problems with customers at my job.
Old Jul 23, 2006
thefever's Avatar
I need a drop
thefever is a jewel in the roughthefever is a jewel in the roughthefever is a jewel in the rough
You could be riding on one lug, like one tire shop decided to do to me.
Old Jul 23, 2006
burke420's Avatar
The World Is Yours!
^^^ i would derfinitley go back and sue them for reckless endangerment, or something. thats messed up!
Old Jul 24, 2006
shmik1's Avatar
you dont balance them?
Old Jul 24, 2006
When I took it to the tire shop to get them balanced, they said the tires were worn down in such a way that balancing them wouldn't stop the vibration. I just wound up getting new tires anyways since they were the original tires on the car from 2000. (this was earlier this summer).
GotSiR
Jun 23, 2016 04:06 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
kaashifv
Interior
Jul 27, 2015 05:28 PM
breanna_17
Jul 21, 2015 04:01 PM
qlitten
Jul 21, 2015 03:12 PM
