braking
Old Jun 4, 2006
instalher's Avatar
instalher is an unknown quantity at this point
braking
hi gang on my o3 civic lx my braking is weak to say the least. i changed the pads to the top of the line bosch but that didnt help. so now i was looking into going with a new set of crossdrilled rotors and some 2 piston calipers. can someone recommend a good set of calipers for me? and should i upgrade the mastercylinder as well?
Old Jun 4, 2006
pads and rotors aren't really gonna help brake performance. and stock brakes are pretty good overall. why do you need better.
Old Jun 4, 2006
Da1lyDr1ver's Avatar
you probably didnt let your brakes break in yet. make sure you bedded the pads in properly and they should start to bite harder. yes, like Gearbox said, our stock setup is pretty good; i even retain it for road racing. if worse comes to worse, i'd suggest better pads, such as Hawk or PBR AXXIS.
Old Jun 4, 2006
XxSoVeReiGNxX's Avatar
Post
if changing the pads and rotors didnt fix your problem, you should check the fluids and yeah the mastercylinder. low pressure or air in the system causes weak braking
Old Jun 5, 2006
civicvtec1ps's Avatar
Search and Learn
Moved to Wheels,Tires & Brakes
Old Jun 5, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
Get some pads geared towards performance. Bosch pads are just DD pads. Xdrilled rotors do nothing, and 2 pot calipers would screw up the bias beyond belief.
Decient pads, blank rotors and DOT4 fluid do wonders. It's not an M3, don't expect miracles.
Old Jun 5, 2006
Zzyzx's Avatar
Autocross Junky
You need to clear up what you dont like about your brakeing.... is it your 60-0 Distance? pedal feel? are you running in to brake fade? ect ect ect...
Old Jun 7, 2006
instalher's Avatar
the braking is spongy and i have to push down alot to get the brakes to bite, teh fluid was just changed, and the brakes have been bleed 3x. its not the mc. as i cant push the pedal to the floor no matter how long i hold kit down.
Old Jun 7, 2006
diskreet's Avatar
The stock brakes are strong enough, but they do fade VERY quickly.
Old Jun 7, 2006
spongy brake pedal is common symptom of air in the lines, but you said it's been changed/bled couple times and sure it's not the mc...
can you isolate if the front discs, or the rear drums are the weak ones? are there any leaks? the only other suggestions i can say is to check the booster and check the pump.
Old Jun 8, 2006
ctx66's Avatar
ctx66 will become famous soon enoughctx66 will become famous soon enough
probably something with the fluid. how many miles on your car? has the fluid ever been changed? i'd look into getting that done, its not too much to have honda do it.
Old Jun 8, 2006
CuRiOuSfIsH's Avatar
Back From The Banned!
either there is air in the lines, or you can look into swapping to a RSX brake mastercylinder but that costs $$$$
Old Jun 8, 2006
Zzyzx's Avatar
Autocross Junky
Welcome to honda brakes...
couple of things here, Make sure theres no air in the lines, and you may want to go to a pad thats got higher inital coefficient of friction.
other wise.... Honda brakes tend to feel like your stepping on a sponge, but they really stop fine.
Old Jun 8, 2006
04civic07's Avatar
Living Life Turn After Turn
04civic07 will become famous soon enough04civic07 will become famous soon enough
if you dont liek the "spongy" feel... you can always upgrade to steel brakelines. with those you cant go wrong. it will help eliminate the lines from somewhat ballooning when you step on the brakes compared to the rubber ones. other than that, i would upgrade the pads to performance ones and if you have drums on your rear, better shoes.
Old Jun 8, 2006
DDragon7's Avatar
At least its not as spongy as Toyota brakes.
Bricoleur
Sep 9, 2015 06:48 PM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
thaler4cuse
Sep 7, 2015 08:25 PM
Josh 1973
Sep 7, 2015 10:10 AM
rainman15
Sep 6, 2015 11:10 AM
