extreme newb Q: how much brake fluid?
Old Apr 28, 2006
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
so here's an extreme newb question that I really couldn't find the answer to ... I found a ton of DIY's on it, but nothing really said how much brake fluid I need for a complete flush/bleed ...
I'm gonna get the super ate blue fluid ... should I get one or two liters?
Old Apr 28, 2006
Zzyzx's Avatar
Autocross Junky
One will do, but get two any ways (not like its all that expensive)
Old Apr 28, 2006
01HonderCivic's Avatar
Don't be a n00b, search ftw
When I did mine, I used slightly more then a litre. Then again I made sure the bitch was flushed...Like zzyzx said, play it safe and get two anyways. And if you don't use it, you'll have some laying around just in case...
Old Apr 28, 2006
blackdragon's Avatar
blackdragon will become famous soon enoughblackdragon will become famous soon enough
get two cuz you might need extra after flushing and bleeding the air out
Old Apr 28, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
^^^ You can flush the system in full at least twice on one can (quart) of ATE. Pick up the blue stuff, just 1 can, then next time pick up the ATE Gold, so when you flush it, you'll know its flushed.
Old May 1, 2006
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
ah, thanks a ton guys ;D
Old May 10, 2006
HondaLuver's Avatar
Its a celebration bitches!
newbie!
401CivicLX
Jun 28, 2005 08:34 AM
izmaxx
23
Apr 14, 2005 10:14 PM
gearbox
Sep 8, 2004 08:57 PM
ak
Nov 16, 2002 04:31 AM
SugarRay
Jan 28, 2002 05:17 PM
