brake pads scratching?
Old Apr 4, 2006
iLOVEmyEM2's Avatar
iLOVEmyEM2 is an unknown quantity at this point
alright guys. after driving for a while, i guess when the brakes get warm, when i start to brake my brakes make a scraping noise. i checked to see if the rotors had and grooves on them but the rotors seem fine. is it time for a break change? also if it helps i have just about 13k miles.
Old Apr 4, 2006
01HonderCivic's Avatar
Don't be a n00b, search ftw
The break wear sensor on my car made a squeaking noise while driving at lower speeds that was very audiable. It disappeared under breaking, So your problem might be that you need some anti-squeal compound on the back? Don't know...But I'd say try that first, It's only a few dollars. If it persists, take it to a mechanic.
Old Apr 4, 2006
shroomster's Avatar
Crayons taste like purple...
shroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to behold
might have a little bit of clearance between the backing plate for the liner and the clip holding the whole pad to the bracket....
GotSiR
Mar 8, 2017 05:33 PM
jpandjf
Aug 3, 2015 05:02 PM
Strycker
Aug 2, 2015 08:40 PM
DerbyDad03
Jul 27, 2015 11:34 AM
General 7th Gen
Jul 9, 2015 10:17 PM
