225/45/17, will they rub with coilovers?
Old Mar 22, 2006
RIC3BOY's Avatar
RIC3BOY is an unknown quantity at this point
Yes, I've searched all throughout forum but still couldn't manage to get a straight answer. A friend of mine is selling a set of Falken Ziex ZE 512's, 225/45/17 for a pretty good price. The only thing which is stopping me is that I'm not sure about the size.
Will 225/45/17's rub on 17x7.5 rims with a 45 offset? Mind you, I have Tein SS's. Does anyone have any experience with this issue?
Cheers
Old Mar 22, 2006
hdave's Avatar
hdave is an unknown quantity at this point
almost certain they will rub, on the inside
but you can get wheel spacers, or do small things here and there to make them fit
Old Mar 22, 2006
daviddittmer's Avatar
daviddittmer is an unknown quantity at this point
Based on what I've learned in this forum, they will probably rub unless you modify the inside of your wheel well ("roll back" the fender?).
Old Mar 22, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
Well you got height adjustment, adjust it up and down, in and out and make them fit. Thats such a huge tire and its so far inboard, my money is it rubs and there's nothing you'll be able to do to fix it.
Old Mar 22, 2006
matt_s's Avatar
Super JDM Member
matt_s is an unknown quantity at this point
i would never throw tires that large on the civ..
Old Mar 22, 2006
burke420's Avatar
The World Is Yours!
i would suppose for you to want tires that big, why even have coilovers, just get some 215/45s and call it a day, that SHOULS work. just get them and see if they work at your local Discount Tire Co. store
Old Mar 22, 2006
RIC3BOY's Avatar
The only reason why I'm considering 225/45/17's is because my friend is selling them for a great price. But since in most likely cases it'll rub, I guess I won't bother. Thanks for the replies.
Old Mar 22, 2006
olytrojan's Avatar
Senior Member
olytrojan is an unknown quantity at this point
i have 225/40r18's on my car and they only rub a little on the inside when i make sharp turns
Old Mar 23, 2006
D17thgen's Avatar
D17thgen has a spectacular aura aboutD17thgen has a spectacular aura aboutD17thgen has a spectacular aura about
ill chime in a little on this. i had 215/45/17 17x7.5, 45mm offset wheels on the civic coupe with skunk2 coilovers. i had to adjust my rear camber kit so it sits a little negative to prevent fender rub. up front, i had the perch set a little above the halfway mark and the rear was 2/3" lowered. otherwise, it would touch if i wanted to tuck my wheels. as for the front, i had to keep it at 1/2" finger gap because i would rub up front during a moderate rough turn at high speeds or just making u-turns.
i can only imagine 225 being worse than what i had. but 215/45/17 was a good choice, just not great for those who wanted to tuck and slam their civic with [me].
Old Mar 23, 2006
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
my 225/45/17's fit fine without rubbing ... but I also don't have fender well covers
Old Mar 24, 2006
blouisgod's Avatar
Life Begins > 6800rpms
why not use a 225/40 ? It has less chance to rub and will probably look better with the smaller sidewall, imo.
Old Mar 24, 2006
RIC3BOY's Avatar
Thanks for all the replies. I decided to order a set of Falken Ziex 512 (215/45/17).
Old Mar 24, 2006
djc's Avatar
djc
djc is an unknown quantity at this point
will the 215/45/17 rub on non-lowered?
Old Mar 24, 2006
HondaLuver's Avatar
Its a celebration bitches!
****, sell me those tires, i had 225/45 tires on my 17x7 inch buddy clubs and they didn't rub, i did have alot of neg camber in the back, but i hooked up like no bodies biz...
eh...
Old Mar 24, 2006
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
eh...
oh REALLY???
Old Mar 25, 2006
D17thgen's Avatar
215/45/17 wont rub on factory spec suspension.
Old Mar 25, 2006
straightfaced's Avatar
straightfaced is an unknown quantity at this point
I noticed when I installed my 215/40/18 with eibach sportsline that on the back inside fender there a plastic piece that would be in the way if you went larger then 215. 215's are perfect for our cars. I wouldnt go larger, no point
Old Mar 27, 2006
e04241's Avatar
e04241 is an unknown quantity at this point
i am running on 225/40/18. inner front left only rubs when i turn the steering wheel all the way to the right.
im using springs from neuspeed (sport) color red.
if u use 225/45/17. most probably the same case, since the profile is higher than a 40 series. are you on lowering springs? stock height should't have a prob
and to add my rim specs is 18x8, offset is +48.. do consider this
Old Mar 27, 2006
HondaLuver's Avatar
Originally Posted by aznboysrfr
oh REALLY???
no, im lying, i still didn't have traction.. lmao
Tedverseti
Apr 23, 2020 01:45 PM
GolNat
Nov 27, 2018 03:32 PM
UltraHDGames
Jun 8, 2016 05:16 PM
Tedverseti
Sep 29, 2015 05:41 PM
beanhead
Sep 24, 2015 12:04 PM
