Question w/Brakes
Old Mar 13, 2006
Dticalman81's Avatar
Dticalman81 is an unknown quantity at this point
Question w/Brakes
My steering wheel slightly shakes now when I brake. A friend told me that my pads look pretty good, but my rotors are probably warped. Now, I might resurface my rotors pretty soon. The question is: Can I just resurface my rotors or do I must buy new pads as well? Someone please confirm. Thx.
Old Mar 13, 2006
fallout's Avatar
fallout is a jewel in the roughfallout is a jewel in the roughfallout is a jewel in the roughfallout is a jewel in the rough
Have the exact same problem! I have no idea what it is, coz i've only put 23k miles on my car.
Old Mar 13, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
You can just resurface, but its almost more economical to just replace the rotors.
Old Mar 13, 2006
CraigW's Avatar
The problem will return soon after resurfacing, Replace them.
Old Mar 13, 2006
jeffsta17's Avatar
jeffsta17 is an unknown quantity at this point
really the problem might return but it depends on the source of the problem. Try an on car lathe, might be the better of the ways to go about it, if the problem is with the whole hub then the on car lathe will counter act that sometimes. Good luck
Old Mar 13, 2006
shroomster's Avatar
Crayons taste like purple...
shroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to behold
you can get a good set of brembo blanks and some pads for around 115 bux now adays and installation is a breeze if you read up on it.
Old Mar 15, 2006
streetglower's Avatar
as with what boilermaker said, it is better to just replace then resurface. brembo blanks can be purchased for around $30 a rotor as a few websites. besides resurfacing is around $10-$30 a rotor. now if it was my car I would just go ahead and chage the pads as well.
Old Mar 15, 2006
Zzyzx's Avatar
Autocross Junky
Its un even pad meterial build up on the rotors surface (not warping) ushually caused by improper bedding of your pads in, or getting the brakes hot then holding them at a stop. but any way the fix is what boilermaker said, either machine them (pepboys does it for around $9 a rotor, or just replace the rotors.
Next time bed your brakes properly!!!
Old Mar 15, 2006
inthenameofweez's Avatar
inthenameofweez is an unknown quantity at this point
Bedding?... Mine's been doing it for a month, and will have my rotors resurfaced this week.
But bedding of my pads? Wtf is that?
Old Mar 15, 2006
Zzyzx's Avatar
Autocross Junky
Stolen from Stoptech
Why is the pad and rotor break-in procedure so important?
PROPER BREAK-IN OF ROTORS AND PADS IS CRITICAL. Not properly doing so can cause permanent damage to rotors and adversely effect overall brake performance. Pads and rotors interact with each other to provide efficient brake performance. The break-in or bed-in procedure is done to condition the pad/rotor interface. Depending on the pad used, more or less pad material is uniformly transferred onto the disc as a thin film. The resins and bonding agents in some pads need to be heat cycled to work properly as well. By not properly bedding in pads, uneven pad material deposits can occur that may cause a vibration. Improper wear characteristics may also show up on either the pads, or rotors, or both. Always follow the recommended break-in procedure for any pads, rotors or brake systems.
http://www.stoptech.com/tech_info/wp_bedintheory.shtml
Old Mar 21, 2006
04civic07's Avatar
Living Life Turn After Turn
04civic07 will become famous soon enough04civic07 will become famous soon enough
i had the same problem with mine. when i took the rotors off, placed a straight edge on it and guess what... it wasnt flat. i tried re-surfacing it , but really, didnt make a difference,so just go get new rotors and pads to go with it
Old Mar 21, 2006
cubanmike26's Avatar
Just got my Hawk HPS waiting for new rotors and don't wanna wait for shipping time..what's the thing with the brembo blanks? can it just be some regular rotors from autozone, pepboys, etc? can anyone recommend some other brand?
Old Mar 22, 2006
shroomster's Avatar
meh = Wagner or raybestos
Old Mar 22, 2006
Jap-Euro Fusion
Just get autozone rotors, whatever brand it is. They're so cheap, it doesn't matter, and they work perfectly fine.
Old Mar 22, 2006
I have autozone rotors and autozone pads on and they work perfectly fine.
Old Mar 22, 2006
sounds good, thanks
Old Mar 22, 2006
Slow Gold's Avatar
I hope I offend you... Get mad
Slow Gold will become famous soon enoughSlow Gold will become famous soon enough
Are brembo drilled any better then your average blank rotor? Is it better to upgrade the rotors or upgrade the pads to improve braking.
Old Mar 22, 2006
Zzyzx's Avatar
Autocross Junky
Drilling offers no performance gain... unless your looking to save a few oz of weight. but they do provide a nice way to force you to buy new rotors more often...
difference in brands, between something like a brembo made blank or your average every day blank would be in the vein design (in the vented area). some allow for better air flow through the rotor. but thats about it.
so, change pads. dont bother with the rotors.
Old Mar 22, 2006
Slow Gold's Avatar
Well since your into auto x im sure you know pads that are good and pads that are bad. what do you recomend?
Old Mar 22, 2006
runner1738's Avatar
do they come bedded from the factory? but they make it seem like you need to go to an empty parking lot install them, then never stop until they are bedded in, in the real world this seems hard to achieve where you can do 10 consecutive 60tp 10 mph decelartions at 80%
Old Mar 27, 2006
runner1738's Avatar
do any street pads come pre bedded then?
Old Mar 27, 2006
Zzyzx's Avatar
Autocross Junky
Nope, because the bedding process does two things.
1. it burns out the binding agent on the contact area of the pad (could be done at the factory)
and
2. it creates a "transfer layer" on the rotors surface for the pad to better bite in properly. (which cant be done at the factory)
Its improperly bedding pads that can cause an un-even transfer layer, which eventually causes the pulsating pedal/brake feel that people say is a warped rotor.
Old Mar 27, 2006
runner1738's Avatar
then how are people supposed to bed them in properly, i mean unless your at a dyno shop or something and can get the car going 60 and slam on the brakes and do 10, i dont see how anybody can bed there pads in correctly then, which means everyone needs to buy new parts sooner, this just doesnt make sense to me, i mean say i go have them installed i leave hte place knowing i need ot bed them in, and can never stop completely, the most i think i could get to was like maybe 30 or 40 then hit the brakes at a stop sign and roll through
Old Mar 27, 2006
Vinnie's Avatar
Vinnie should not be trustedVinnie should not be trustedVinnie should not be trustedVinnie should not be trusted
whats the average life (miles and/or years) span for stock rotors?
Old Mar 27, 2006
DDragon7's Avatar
That depends on your driving habits.
Old Mar 28, 2006
runner1738's Avatar
well i have 25k on my car, and i was told i have runout on my rotors so thats the life span, on my other car the pads gave out at 30k on my 2002 ex
Old Mar 28, 2006
Zzyzx's Avatar
Autocross Junky
OEM and oem equivilent pads require very little bedding. in fact the bedding process for OEM pads is this
400 to 500 miles of moderate driving is recommended. Consumer should avoid heavy braking during this period.
some performance pads require a more hands on approch like Hawk,
After installing new pads make 6 to 10 stops from approximately 35 mph with moderate pressure. Make an additional two to three hard stops from approximately 40 to 45 mph. Do not allow the vehicle to come to a complete stop.
as far as where you should bed your pads.... Traffic should be avoided. Try to find a lesser used road in an industrial area or something, try at night ect ect ect... its not that hard.
Old Mar 28, 2006
shroomster's Avatar
I haven't checked the faq yet so I'll delete this if i find the answerm, but can you resurface(cut/turn) slotted rotors?
Old Mar 28, 2006
Zzyzx's Avatar
Autocross Junky
I've heard some shops will and some wont...
Old Mar 28, 2006
That's good to know since I got these same pads seating at home.
Pepboys have these "ProStop" rotors for like $16.99 each and Reysbestos for $55.99 EACH?? I mights as well get the BB for the last price, but..are the ProStops any good?
