Question w/Brakes
Old Mar 28, 2006
  #31
Dticalman81's Avatar
Dticalman81 is an unknown quantity at this point
car shops tighten my lugs so hard, the rotors warp early. What's up with that?
Old Mar 28, 2006
  #32
shroomster's Avatar
Crayons taste like purple...
shroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to behold
Originally Posted by cubanmike26
but..are the ProStops any good?
the adage (sp) you get what you pay for doesn't always hold true for auto parts, its weird really. try em out and let us know...I just wouldn't go auto-x or anything, I'd think they'd be more of the daily light driver/traffic and stop&go type stuff.
Old Mar 29, 2006
  #33
runner1738's Avatar
Originally Posted by Zzyzx
OEM and oem equivilent pads require very little bedding. in fact the bedding process for OEM pads is this
some performance pads require a more hands on approch like Hawk,
as far as where you should bed your pads.... Traffic should be avoided. Try to find a lesser used road in an industrial area or something, try at night ect ect ect... its not that hard.
so will it deystroy the bedding process, if you drive home like 5 miles first, then at night go out and bed them in properly? maybe i didnt bed them correctly when i first got the car and thats why they wore out early, but it sounds like i should juist go with hawk ceramic since im sure hte bedding process will be more like oem then with hawk hps pads
Old Mar 29, 2006
  #34
Zzyzx's Avatar
Autocross Junky
They will be fine, THe problems start when people dont bed the pads and then use the brakes hard...
Old Mar 29, 2006
  #35
runner1738's Avatar
i have an lx so i know that it will be easier for me to be harder on the brakes then someone with abs
Old Mar 29, 2006
  #36
Zzyzx's Avatar
Autocross Junky
Not really, what I mean by "hard" could be described as heavy use... like if your on the freeway and you slam on the brakes several times in a row.
Old Mar 29, 2006
  #37
cubanmike26's Avatar
I know changing pads doesn't require bleeding the brakes, but my brake's fluid is kinda low..within specs, but still kinda low..should I bleed them once I change the pads and the rotors or simply add fluid?
Old Mar 30, 2006
  #38
shroomster's Avatar
no and no....only when adjustments are made should you bleed the brakes. the reason the fluid is low and within specs is because when the pads wear, the piston in the caliper travels a longer distance to make contact with the pad. the piston is moved hydraulically (by the brake fluid) therefore the more wear on the pads, the lower the fluid will be because it has to push the piston out farther.....now you can bleed the brakes whenever you want to, but it's not necessary unless certain problems are occurring......
Old Mar 30, 2006
  #39
That's cool..thanks
Old Jan 18, 2007
  #40
mrb420's Avatar
mrb420 is an unknown quantity at this point
What problems?
What certain problems?
And, is $73.00 too much for OEM rotors from the dealer?
My mechanic, told me never to buy non-OEM parts. Only buy from the dealer. Maybe he has stock in Honda?
Old Jan 18, 2007
  #41
djmota's Avatar
way to bring a year old thread back from the grave
Old Jan 24, 2007
  #42
tfnaaf's Avatar
BLDNPSI Mod
Being that someone brought it back from the grave Below is the most likely cure for the problem. The improper bedding of the brakes is SOOOOO uncomon for 99.9999999% of the cars on the road
Originally Posted by Jeffsta17
really the problem might return but it depends on the source of the problem. Try an on car lathe, might be the better of the ways to go about it, if the problem is with the whole hub then the on car lathe will counter act that sometimes. Good luck
Old Jan 24, 2007
  #43
tfnaaf's Avatar
BLDNPSI Mod
Ohhh and just buying new rotors with a warped hub without proper indexing of the rotor, the problem WILL return
Old Jan 24, 2007
  #44
DragassD's Avatar
DragassD is an unknown quantity at this point
Would buying Brembo slotted be better than buying Brembo blanks? Or just a waste of money. slots keep the disc vented better than blank right?
Old Jan 24, 2007
  #45
tfnaaf's Avatar
BLDNPSI Mod
in therory the slotted will help the out gassing of the brake material. But for most people no, its not going to be benifical at all. I know some people will say that the vents wont help at all because of the advances in brake material. I agree that it less likely to happen with moderen material but still can happen
Old Jan 26, 2007
  #46
DragassD's Avatar
So, the only way to truly improve braking would be to use larger discs and calipers?
Old Jan 29, 2007
  #47
Zzyzx's Avatar
Autocross Junky
If by improve you mean changing the feel of the brakes or increasing the thermal capacity of the brakes.
The only surefire way to improve your stopping distances (60-0) is by getting stickier tires.
Old Feb 2, 2007
  #48
DragassD's Avatar
so, your saying by doing a rear disc conversion, and putting for instance rsx-s brakes on the front and back, that it would be a waste of time? I dont think so.
Old Feb 3, 2007
  #49
rice4lyfe's Avatar
rice4lyfe will become famous soon enough
the main reason for rotor warpage is improper torque of the lug nuts. Many people dont realize this, but most mechanics just zip the lugs with the gun, where they will have improper pressure distribution.
Old Feb 4, 2007
  #50
2002civicLX2002's Avatar
The only Wyoming Redneck on here
2002civicLX2002 will become famous soon enough2002civicLX2002 will become famous soon enough
^^^^true, but they can also be caused by a large amount of heat and pressure applied to the brake at any given moment. also, larger rotors, and better pads will help wit braking, but stickier tires will help the most. if you own a civic and dont have a 250+hp you dont really need to worry about upgrading brakes for any other reason than looks.
Old Feb 5, 2007
  #51
LT2004ever's Avatar
I wil fix vBPlaza today
yup, its called the super bump
Old Feb 5, 2007
  #52
Zzyzx's Avatar
Autocross Junky
You'll be able to run the brakes harder, longer... But if you keep the same tires, your stopping distances wont have changed much if at all.
Ask the guys at Stoptech and they'll tell you the same thing.
A little 101 on brakes
Class 1: Those poor Rotors
Clas 2: Braking
Systems…in Plain English
robjcivic
Mar 12, 2017 12:10 PM
JMKendrick
Sep 16, 2015 06:17 PM
Bricoleur
Sep 9, 2015 12:23 PM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
junkyardguy
Sep 2, 2015 06:07 PM
