coated/plated rotors
http://www.tirerack.com/brakes/brake...ar=&perfCode=A
these for example, how long does it take for the coating to wear through, or is it somehow tough enough to not do so?
I just burnt my tongue
coating is for reducing corrosion when not in use on a car...the rotor surface once used will start to rust even after cleaning the rotor with brake cleaner b4 install
Originally Posted by kiwi133
so whats the point? keep rust from forming on the edges/inner venting/mounting surfaces? where the pads don't touch?Joined: Nov 2003
actually it does help prevent rust formations on the hub surface that can cause run out in the rotor surface over time. Not a factor here in idaho much. But i guess in salt country it could be
Junquito89
Sep 27, 2015 10:22 PM
Bruce2
Sep 27, 2015 08:45 PM
pilebuck13
Sep 21, 2015 10:45 PM
