Need the size of the Rear brake line flare nut at the wheel cylinder
As the title says, does anyone know the size of the flare nut on the brake line at the rear wheel cylinder?
well all I really am looking for is what size flare nut wrench fits that nut on the brake line. so if its 10MM, that helps me out. I would use a wrench, but have had problems using regular wrenches in the past with removing brake lines.
Touge
May 20, 2015 10:53 PM
