Grinding noise
Old Sep 26, 2005
southpasdena's Avatar
Super Member
southpasdena is an unknown quantity at this point
Grinding noise
Aite, I have a little problem. I am assuming the brakes are the most probable since the noise stops when i step on the brake pedal. When i am driving, half the time their is a squelling grinding noise coming from one side, maybe both, and then it stops, then maybe starts again when i turn the wheel etc. Could my brakes be worn down, something out of line? I have not hit anything and have not changed the brakes since i got the car, and i have driven 42,000 miles, considering about 25,000 miles where barely to no brakes were used due to interstate driving. A friends father who said he would do he brakes for free checked and said my brakes are still good. So what is the deall...........?
Old Sep 26, 2005
Al Gore FTW's Avatar
jdmtytedoridori
probably the "telltale" on the brake pads. means you need new pads is all.
Old Sep 26, 2005
dru106's Avatar
ThE CoRRupToR
Dam, 42k miles and never changed ur brakes!!! I bet you that the pads are metal to metal and its grinding against the rotors!! CHANGE UR BRAKES ASAP!!!!!!!!!!!!!
Old Sep 26, 2005
SLO REX's Avatar
250+ awhp Stage 2
I have 50k on my brake pads and there is no noises coming from mine.
Old Sep 26, 2005
Ashhole's Avatar
Ashho-san 7thgen Ninja
Ashhole will become famous soon enoughAshhole will become famous soon enough
sounds like brake pads. if your metal-metal your prolly gonna need new rotors too. perfect time to go drilled n slotted
Old Sep 26, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
How about a perfect time to not go drilled and slotted. They're worthless and stop worse than a blank face rotor, not to mention they crack.
If you've gotten 70Kish out of the brakes, they're probably going. If someone just stuck a head in there and looked, I'd pull a caliper off and look at the pads. You'll see if the wear indicator is sticking out. Also pull a drum off and check to see that there's still lining left on the backing. Grinding noises from brakes usually mean they're gone.
Old Sep 26, 2005
streetglower's Avatar
well just because you have alot of pad life left doesnt alwasy indicate the brakes are "good". You could have good pad life, and worn rotors. they are several things to check for. With the civics, it is common for the pads to shift around in the caliper brackets when stopping which gives you that grinding noise. I have had it and still get it. I think a possibly fix is to add a few sets of shims in there. I suggest you pull off all 4 wheels, and find the specs for the minimum thickness of the rotors and drums and measure both. You may have one out of spec. you could also possibly have a pice of debris stuck in between the pads and rotors. You could have a sticking caliper causing one side to do all of the work. Did he tell you if both side were wearing evenly?
Old Oct 29, 2005
CivicRookie's Avatar
Jeremy's Iron
CivicRookie is an unknown quantity at this point
I am having the exact same problem right now! I'm actually going to change the pads today to see if that makes a difference. Did you ever get it resolved, Southpasdena?
Old Oct 29, 2005
Super Member
yes i did, one of the pads became loose
Old May 18, 2008
mayorz's Avatar
mayorz is an unknown quantity at this point
Re: Grinding noise
Hello Guys!
I also have exactly that problem. If I am driving on a not totally smooth road, "metallic" noise coming from all wheels (disc brakes are in front and rear as well). But as I press the brake pedal the noise disappears all at once. The front pads are brand new original Honda parts. So even if the rears are worn I do not understand why can be heard noise from the front wheels as well?
Thanks for your answers!
(mayor from Hungary)
nirvanaguy
25
Oct 26, 2017 07:26 PM
siliconvalley
Sep 15, 2015 09:48 PM
junkyardguy
20
Sep 6, 2015 10:07 PM
tooly145
Sep 5, 2015 01:05 AM
JJ291
Sep 2, 2015 11:49 PM
