New wheels=new alignment?
Old Aug 30, 2005
Civic_RedLine's Avatar
im stock now! T.T
Civic_RedLine will become famous soon enough
Can anyone let me know if new rims need a new alignment after mounting them? I just had some bent rims then switched to honda rims and I just need to know if i need alignment. thanks for any advice in advance...
Old Aug 30, 2005
kasimmmmm's Avatar
no you shouldn't need alignment... only when you lower it. i switch took of my rims and put on the si wheels, alignment was just fine for me.
Old Aug 30, 2005
im stock now! T.T
i balanced the wheels so it could be the tire/wheel installer that put the tires on wrong? cuz i used the same tires on my damaged rims on my new rims, but maybe the guy put 1 rear tire to the front and one front tire to the back, would that cause any trouble? I feel safer with my bent rims.
Old Aug 31, 2005
kasimmmmm's Avatar
is the tread on your new tires even all around? wuts the ride like exactly? is the car pulilng to one side? is the ride rough? what is it exactly?
Old Aug 31, 2005
im stock now! T.T
the car feels rough like it moves left right but not enough to move the car, just the steering wheel.
Old Aug 31, 2005
streetglower's Avatar
is the steering wheel vibrating?
Old Sep 1, 2005
im stock now! T.T
no its not... i put more air in cuz the tires were at 30 psi and now at 40 psi and seems somewhat better, I think cuz my tires are thin? honda recommends 205/50/16 tires but mines are 205/45/16 and i made sure before I bought the honda rims that if those tires would work and they told me the 45 and 50 difference is only on thickness of the tire, not the size.. hmm.. i feel as if my bent rims rode better.
Old Sep 1, 2005
crazyasian's Avatar
crazyasian will become famous soon enoughcrazyasian will become famous soon enough
uh thats a bit much for air, thats kinda askin for a tire blow out. drop the air down to 32-35 psi. it might feel a lil more softer. if yer saying like if u drive thro a little grove in the road and yer steering wheel feels like it shifts thro that grove than thats normal. you just have a bigger contact patch. i thought the same but my friend told me thats normal b.c the tire is moving thro the grove. with the smaller contact patch u wont see that b.c its small enough to ride thro it with no problem. i dont exactly have the full explanation(sp?) of it but its normal. that is all true if u went from smaller diameter tires to the wider tire. but def the biggest thing u need to do immediately is drop the air pressure to 32-35 psi cause if u drive right into a pot hole or something yer tires will either buldge or explode.
as for gettin an alignment, it is good to get an alignment whenever u dismount and mount tires to the car b.c it may move things around but it isnt that necessary. kasimmmm is right, it is only necessary to do an alignment when u lower the car.
Old Sep 1, 2005
soonercivic's Avatar
soonercivic is a jewel in the roughsoonercivic is a jewel in the roughsoonercivic is a jewel in the roughsoonercivic is a jewel in the rough
if the ride is your problem, a thinner tire will ride rougher usually.
pizzahutcombo
Suspension
Jul 13, 2021 09:41 PM
BryanM.
Aug 29, 2015 03:26 PM
jedi
Aug 3, 2015 04:26 PM
Dangerousjordan
Jul 28, 2015 08:24 AM
carid
Wheels and Tires
Jul 20, 2015 07:15 AM
