si disc brakes and camber kit
Old Aug 30, 2005
chefjnr's Avatar
chefjnr is an unknown quantity at this point
i have a 2001 civic ex, and just got all the parts off of a 2003 civic si to do the rear disc brake conversion- will the camber kit I have on my ex work with the si's brakes, or do I need to get a civic si camber kit?
thanks,
jordan
Old Aug 30, 2005
blouisgod's Avatar
Life Begins > 6800rpms
no, the upper control arm you have will work.
Old Aug 30, 2005
cj2185's Avatar
cj2185 is an unknown quantity at this point
how much did the rear brakes cost you?
Old Aug 30, 2005
02SILVEREX's Avatar
02SILVEREX has a little shameless behaviour in the past
First let me say... I have an 02, with the rear disc of an 02 si.
On your conversion, are you upgrading to 5 lug?
Looking at the part cattalogs... The rear upper arm IS the same between the the 02 and 03 SI's. So that being the case... The camber kit for the regular civic is fine. You won't have any problems.
What e-brake cables did you decide to go with? Did you choose to use a proportion valve? (I didn't and have no problems)
GolNat
Jan 12, 2021 09:06 PM
chrisjackson321
Jul 12, 2015 03:00 PM
OptimisticWay
Jul 10, 2015 04:31 PM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
General 7th Gen
Jul 9, 2015 10:17 PM
