Will 18 x 7.5 wheels fit? Anyone running them?
Old Jul 3, 2005
ccajun4real's Avatar
ccajun4real is an unknown quantity at this point
I am looking at a set of wheels that are 18 x 7.5 with a +42mm offset. Anyone running these? Will they work with a 215/40-18 tires? Here are the specs I got from the wheel width calculator and I see that they will push the wheel out about .86 inches, just not sure if I will run into trouble with that kind of gain?
Info about the Existing Rim
Offset (in mm) 45
Width (in Inches) 6
Width Outside Mounting Surface 31.2
Width Inside Mounting Surface 121.2
Info about the New Rim
Offset (in mm) 42
Width (in Inches) 7.5
Width Outside Mounting Surface 53.25
Width Inside Mounting Surface 137.25
Inches Millimeters
Difference in Width 1 25.4
Offset Difference -0.118110236 -3
The outer edge of your new wheel will be 22.05 mm further out than the existing wheel 0.868110236 Inches
The inside edge of your new wheel will be 16.05 mm further in than the existing wheel 0.631889764 Inches
Old Jul 3, 2005
XSRCivic's Avatar
XSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really nice
with no drop you will be okay.. i had the same size on my car last year and had 0 rubbing problems.
Old Jul 4, 2005
I have an Eiback pro kit that is a 1" drop all around. What if I used 225/40tires? Thanks
Cajun
Old Jul 5, 2005
AzNmiKex215's Avatar
2k1civic.com O. G.
defintiely it will fit.
i got 18 x 8 with 43+ offset and it fits like a glove. i can slam my car to hell too on D2 racing coilovers.
Old Jul 6, 2005
So you are running 225 tires? Thanks bro
Cajun
Old Jul 6, 2005
2k1civic.com O. G.
nah im running 215, which is the minium for an 8 inch wheel. (The wheel kinda pokes out and doesnt have that seated all the way look, but im sure its fine becuase i went to a drifting event and the drift cars tires were the same way).
215 for 7.5 inch wheel width is probably perfect. you can go thinner but like subaru once said, "wider is better"
boostedboxer
May 25, 2015 10:05 AM
eorlando1
May 17, 2015 11:16 AM
bsmiley
Apr 27, 2015 01:27 PM
bluecoupe
Dec 6, 2001 10:59 AM
EvilTwin
Nov 8, 2001 12:17 PM
