brembo rotors
Old May 9, 2005
gass03ex's Avatar
gass03ex is an unknown quantity at this point
brembo rotors
anyone know of any online retailers that sell brembo cross drilled and/or slotted rotors?
Old May 9, 2005
MisterFrankieJ's Avatar
MisterFrankieJ will become famous soon enoughMisterFrankieJ will become famous soon enough
http://www.importrp.com/catalogm.php...year_name=2002
Old May 10, 2005
streetglower's Avatar
www.tirerack.com
Old May 12, 2005
Stachmo's Avatar
"You leave me in the trenches taking Grenades, John"
Stachmo is an unknown quantity at this point
on that note...does anyone know how well Brembo 'blanks' work? I've seen them go for as cheap as $30 and I'm very interested in purchasing some if they show at least a little gain in performance...
Old May 12, 2005
el_ben2's Avatar
CivicMexicano Is My Daddy
el_ben2 is an unknown quantity at this point
i just have seen the aplications of this rotors...
and wanna know if all the rotors from 1990 to 2k5 civics are the sames?
i mean i can order an 6th gen front rotors and itll fit?
Old May 12, 2005
southpasdena's Avatar
Super Member
southpasdena is an unknown quantity at this point
They are just regular rotors, no gain in performance. I would guess they are cheaper than OEM and are just as good quality. They may possibly resist warping more, not to sure.
Old May 12, 2005
gass03ex are you having any over heating problems?
Old May 12, 2005
dezod's Avatar
7thgen Power Maker
[clears throat]
http://dezod.com/pd_brembo_sport_fro...0102_civic.cfm
Old May 12, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
^ sweet price
Old May 12, 2005
Zzyzx's Avatar
Autocross Junky
To clear a few things up....
Drilled rotors should pretty much be avoided in high performance applications.
Slotted rotors may be usefull as they help reduce the chance of glazing pads under Heavy repeated use (Track time)...
other wise, there will be little to no noticeable improvement in braking performance with either over a "blank" assuming you only change the rotors. You want shorter stops, get better tires.
Old May 12, 2005
Stachmo's Avatar
thats what I was looking for...
Dezod if you are planning on selling the blanks then drop me a pm cause I'd buy them...
I was just wondering if anyone has any experience with them (as far as how long they've lasted, etc.)? I'm not expecting better braking power, I just want a new rotor cause mine's a little rusty.
Old May 12, 2005
Stachmo's Avatar
oh my bad...I just saw that you do sell the blanks Dezod...
Old May 12, 2005
Zzyzx's Avatar
Autocross Junky
Brembo Rotors still rust. If you want one that doesnt you'll need a Nickel plated or other wise coated one.
Old May 13, 2005
Stachmo's Avatar
would the slotted or drilled Brembo rotors not rust? And would I see any loss in brake power if I did put slotted or drilled rotors with just new brake pads?
Old May 13, 2005
Zzyzx's Avatar
Autocross Junky
Like I said, you should see no difference in stopping power between Drilled slotted or blank rotors. As far as if they would rust... not sure, never used them. just so you know, rotors rust, its just something they do, and there are relitivly few on the market that are coated to inhibit rust. It may just be something your going to have to deal with.
SammySC
121
Apr 7, 2017 07:43 PM
Mad Dog Tannen
Oct 19, 2016 08:12 PM
Junquito89
Sep 27, 2015 10:22 PM
Bruce2
Sep 27, 2015 08:45 PM
pilebuck13
Sep 21, 2015 10:45 PM
