need help...still vibrating
Old May 4, 2005
gOtRyce's Avatar
gOtRyce is an unknown quantity at this point
so i got new 18's about 2 weeks ago. put them on...car vibrated between 50 an 60 mhp. so i got my wheel rebalanced....$60. Still vibrated. So i got hub centering rings...$23. still vibrating. Car pulls to the right...kinda. Do i need and alignment....and will that get rid of the vibrating????
Old May 4, 2005
runner1738's Avatar
you should always get an alignment done, but if after hubcentric rings and balancing of the tire and it still doesnt feel right, do you think it could be because your not used to the 18s? how is it vibrating like what exactly are you feeling?
Old May 4, 2005
gOtRyce's Avatar
the car is pretty smooth up to 50 mph...then it shakes. i feel it in the steering wheel and the wheels. then over 60 mph it smooths out again. it's pretty noticable. any thoughts??
Old May 4, 2005
nitroal1973's Avatar
Broken Road......
nitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to all
What company did the balance, and how did they do it?? Weights on the inside only, dynamic, etc.
Old May 4, 2005
gOtRyce's Avatar
sears auto did balancing...dynamic i think. weights only on outside....
Old May 4, 2005
gOtRyce's Avatar
oh yeah....got another question. are hub rings supposed to stick out of the wheel at all... because mine went into the wheel. i don't see how they could help align the wheel at all.....thanks
Old May 4, 2005
runner1738's Avatar
yes they fit into the hub of the wheel they should be flush with it, and not stick out
Old May 4, 2005
Pharoh's Avatar
Bobaganoosh!
sorry...title cracked me up...lol.
Old May 4, 2005
blouisgod's Avatar
Life Begins > 6800rpms
they should stick out a hair. when you torque the lugs down, the plastic ring should compress and fill the housing area and create a cushion between the rim and the hub.
check your tire pressure first off. check your lugs to make sure they are tight. next, get an alignment. more than likely, you hit a bump or pothole and your alignment is off; that is unless your rim is bent.
btw, any wheel that seems to be off balance, move it to the back passenger side to minimize and vibration that you'll feel.
Old May 4, 2005
Broken Road......
When we can only put weights on the insdie of the wheel, we can still balance on both planes, by using clip-on weights on the inner lip, and stick on weights on the inner part of the wheel. With my 21540R18 & Motegi's I get a nice smooth ride by doing it this way. See if you can find a shop that can do this.
Old May 4, 2005
xDCx's Avatar
xDCx will become famous soon enoughxDCx will become famous soon enough
have u lowered ur car? if so might need a camber kit.
Old May 4, 2005
tfnaaf's Avatar
BLDNPSI Mod
NO matter what ANYONE says it is IMPOSSIBLE for an alignment to cause a vibration directly. This includes camber kits!!! Vibrations are caused from rotating mass ONLY( tires, wheel, axles, transmission, engine............)! Assuming the car didnt vibrate before then its either a bent wheel, bad tire, or poor balance job( hub centric rings included ) Let me say one more time ..... IT IS IMPOSSIBLE FOR AN ALIGNMENT TO CAUSE A VIBRATION
Old May 4, 2005
gOtRyce's Avatar
so i ordered rings that are 56.1 to 73 mm. when i put them in, they went into the rim all the way, did not stick out at all, did i order the wrong ones???
mgrantaz
General
May 2, 2022 05:40 PM
jdawgzcivic
17
Feb 1, 2020 04:16 PM
Wariogamer
Sep 29, 2015 09:49 AM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
FistRock
Sep 4, 2015 08:00 PM
