The Ugly Rust noise when you break
Old 04-28-2005
nova4dr_racer's Avatar
nova4dr_racer is an unknown quantity at this point
It probably hapened to everybody and its now my turn ..
anyways I was wondering which part of the break is the cause of the little noise (turn off) when you break? Because if its the disc ill take advantage of the moment to change my discs to the big AEM ones
Old 04-28-2005
Jap-Euro Fusion
Boilermaker1's Avatar
Its probably the pads. High metal content pads will squeek.
Old 04-30-2005
pbfoot's Avatar
brake dust. if its been raining and your car has been parked the dust rusts and you get that grinding noise sometimes when you first go. that could be it also.
Old 04-30-2005
SuperMODrizd
C2i0v0i1C's Avatar
most of the time thats the warning system to say ur pads are tooo low
Old 04-30-2005
ncirom2003's Avatar
the pads themselves have small metal pieces sticking out to squeal to let you know to check them out soon, it could be that or if you do alot of light braking for a long distance you mightve glazed over your rotor and made the surface so smooth that now it stops worse and squeaks, most common is on a rainy day the raw metal of the rotor will rust but its so little that after a stop sign or two its gone. be more specific of what it sounds like and when you hear it i could help more
15EXCoupe
07-30-2015 12:59 PM
suburbanite
07-17-2015 03:05 PM
f575gtc
Transmission
07-13-2015 09:16 PM
Causemo
07-04-2015 07:11 AM
Quick Reply: The Ugly Rust noise when you break
