Need help bleeding the ABS Hydraulic Modulator
Old Apr 11, 2005
56kz2slow's Avatar
56kz2slow is an unknown quantity at this point
I just replaced my master cylinder on my 97 Civic, I started by bench bleeding the master cylinder and then installed it. My Haynes manual says to bleed the AMS Hydraulic Modulatur using the bleed screw on it. Mine does not have a bleed screw, just 6 brake lines, 2 coming from the master cylinder and the others going to the wheel. Since the ABS hydraulic modulator did not have a bleed screw, I proceeded with bleeding the brakes as as normal: RR, LF, LR and RF. I did this with the enging off.
After this, the brakes still feel spongy. Since the instructions for bleeding the ABS hydraulic modulator said to do it with the engine running to build up pressure in the ABS system, I started the engine and tried bleeding it from the right rear wheel, but there was nothing coming out of the rear wheel. Makes sense since the brake were not applied.
How can I go about bleeding the ABS hydraulic modulator when there is no bleed screw?
Thanks in advance for your help.
56kz2slow
Old Apr 11, 2005
etdigitalis's Avatar
etdigitalis should not be trusted
I'm not sure how you went about bleeding your brakes initially, whether you had a buddy step on the pedal for you or whether you used a hand-pump, but when you did that it should've bled your ABS modulator as well. That's my guess. As far as you're brakes feeling "spongy", maybe some SS brake hoses would help
Old Apr 12, 2005
opticalvetc's Avatar
opticalvetc is an unknown quantity at this point
Bleeding brakes on ABS equipped cars is different than no- ABS cars. You gotta cycle the ABS pump. This does require a special tool. Take it to Honda and have it done properly. No sense trying to save a few bucks when it comes to stopping.
speedlever
Sep 24, 2015 07:18 PM
stank
Sep 16, 2015 07:40 AM
powman02
Sep 15, 2015 07:38 PM
Bikergofast
Sep 12, 2015 01:36 PM
thaler4cuse
Sep 7, 2015 08:25 PM
