Rota slipstreams 17x8 are they too big???
Old Apr 2, 2005
civicman18's Avatar
civicman18 is an unknown quantity at this point
Hey guys so i finally found a 5 spooke that i really like but is it to wide to run with the 04 vics. If i run a 215 40x17 will i rub or can anybody answer this question for me please.
Old Apr 2, 2005
sam777's Avatar
sam777 is an unknown quantity at this point
ah didnt rota slipstreams biggest size come in only 16"??
also i think it depends on the offset....anything above 40+ might fit you probably got to test fit it.....
Old Apr 2, 2005
Xenin's Avatar
Superior Evolutionary Element Destined-factor
Xenin is an unknown quantity at this point
nope, rota went even bigger.
Old Apr 2, 2005
olytrojan's Avatar
Senior Member
olytrojan is an unknown quantity at this point
yea what he said. the thing you need to worry about the most is the offset. you shouldn't have any problem fitting a 215/40 on there as long as the offset anything between a +38 and +44 you should be fine.
Old Apr 2, 2005
CivicMexicano's Avatar
El Pinche Turbo Mexicano
CivicMexicano is an unknown quantity at this point
mmm you should really look into that, for all i know Slipstreams in 17's only come in 5 lug patterns........
Old Apr 2, 2005
olytrojan's Avatar
Senior Member
^^^ i think he's right. i did some looking around and they make the 15 and 16 on 4 lug, but i couldn't find any 17's in 4 lug. maybe because its a new size they just haven't released the 4 lug yet?? i don't know but you should check into it
Old Apr 2, 2005
sw388integra's Avatar
yeah, they're called regamasters, lol...you can find some 17" "spoon" wheels on ebay, but i doubt the size will be 8" wide!
Old Apr 2, 2005
Vantage's Avatar
Vantage should not be trusted
regamasters are spoon rims, they are expensive and JDM. rota copied this wheel when they designed the Slipstream, and yes they come in 17x8's.
Old Apr 2, 2005
civicman18's Avatar
Thanks for all the replies guys. Vantage you have rota slipstreams where did you get them and are they 4 lug with 8inches wide do you rube?
Old Apr 3, 2005
Vantage's Avatar
sry dude, i dont have slips. someone just photoshopped them onto my car. Also, if u cant find Slipstreams in 17x8's. Try Exel race? i think thats wat they are called. they are the exact same rim as the slip, and they have 17x7" wheels for sure, but not 17x8. I have seen them for pretty cheap too.
heres a quick link i got.
exel race
Those damn rip off even stole spoon logo's
ON 2nd look, they are a little different than the slipstreams. but i like them more.But i wouldnt order from wheelmaxx after seeing the post a right below this 1.
Old Apr 3, 2005
gangrel138's Avatar
gangrel138 is an unknown quantity at this point
It shouldn't rub as far as I know unless your car is dropped over an inch. I'm running 15x8's with Hankook 225/50/15's and no rubbing problems. Now when I put my progess coilovers on it may be close but I won't know until I try.
Old Apr 3, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
Regamasters are Russian, not Japanese. Desmond makes Regamasters and SW388s and they're forged in Russia.
Old Apr 3, 2005
exactly!!!! stamped "made in russia" on the sticker on the inside and engraved on the inside spoke!
Old Apr 3, 2005
Vantage's Avatar
i thought they were made at the same place, and just stamped different names. My mistake
Old Apr 3, 2005
Both are made in the same place and stamped different
Old Apr 4, 2005
civicman18's Avatar
Thanks guys i think i am going to get the 17x8 even though i am getting omni coilovers when tehy come out i shouold be ok.
Old May 14, 2019
Biggz's Avatar
Biggz is an unknown quantity at this point
Re: Rota slipstreams 17x8 are they too big???
HI did the 17x8 fit and what offset did you use
Old May 14, 2019
Colin42's Avatar
Thread is 14 years old
SilverVTEC
Wheels and Tires
Feb 28, 2007 11:12 AM
DaSilverCivic
Jul 10, 2006 09:52 PM
JohnH
Oct 27, 2005 08:47 PM
civicman18
Apr 26, 2005 08:10 AM
MYK1013
Dec 12, 2004 11:09 PM
